Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
My dishwasher is not cleaning properly, the lower arm in not rotating
  • Bosch Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
l;;l'
Posted on Mar 27, 2011
Why doesn't upper spray arm function properly?
A couple of scenarios could cause this problem but the simplest might be the way the dishwasher is loaded. The upper spray arm rotates when water is pumped through the vertical supply tube and into the arm. Make sure that you are not loading the lower rack with items that interfere with the rotation of the upper arm rotor. It might also be a good idea to verify that the feed tube that goes to the spray arm is securely connected to the vertical supply tube.
Dec 02, 2015 | Kenmore Dishwashers
Lower spray arm won't rotate
should have complained to them 2 years ago seems to me if it didn't clean properly .
May 05, 2015 | Dishwashers
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
My dinner plate stops the arm rotating, why? model fdud4812
Both upper and lower washing arms operate on the water pressure and angle of water flowing thru them.
Pressure provided by water pump.
Just about anything that contacts the rotating arm can stop it.
Best thing to do is re-arrange items in dishwasher so that arms can spin freely.
One can always spin washing arms by hand to ensure proper clearance.
Hope this helps...
Jul 30, 2011 | Hotpoint Dishwashers
Lower dishwasher arm not rotating
Probably blocked spray arms is the cause of the unit not cleaning properly or rotating. Remove each spray arm (there are 3 in total) and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | GE Dishwashers
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Upper arm does not spray
Dig deeper, until you find filters. Those are probably clogged. You may need a screwdriver...
Dec 29, 2007 | Kenmore 15952 Dishwasher
Lower arm won't spin
the arm only rotates with water shooting out of the angled jets at the end of the arm and these are probably blocked ( i assume it is free to totate manually) take the arm out and run water into the centre hole and this will help push whatever is blocking it to a visible position - usually rice or sweetcorn. you say there are no obstructions in arm but when no water flowing, the blockage tends to slump back into the main body of the arm and out of sight
May 20, 2007 | Maytag 24 in. MDBS661A Built-in Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
66 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
