Question about Stihl Saws
NEED PRIMER BULB FOR STIHL TRIMMER MODEL HL-90K ALSO AIR FILTER ELEMENT
    Novelist:
  • 157 Answers
Hello. Here's the links to the authorized dealer search by Stihl. Hope you find one close.
If this has helped, please rate it.
Thank You.
Canada: http://www.stihl.ca/DealerLocator.aspx
USA: http://stihldealer.net/locator/
Posted on Mar 24, 2011
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Stihl chain saw diagram primer bulb
need new carb... Primer plate is bad. They will run without it working. Your idle problem is separate from this issue. Fresh fuel/oil mix might help. Some Stihl carbs we just replace because they are cheaper than trying to rebuild...
Nov 12, 2013 | Craftsman Convertible 25cc. Gas Line...
Stihl fs80av
generally you have 1 line from the tank that has a fuel filter attached to it that goes to the inlet port on the carb, 1 line from the carb to the primer bulb, and 1 line from the primer bulb back to the tank. when you press the primer it draws fuel through the carb and returns it to the tank through the primer bulb
Oct 13, 2013 | Garden
Both my Echo line trimmer and Stihl hand held blower. No fuel in the bulb on both, I suspect bad fuel. If so, how do I fix?
Check INSIDE the fuel tank. It is possible the fuel line inside the tank has deteriorated and the filter broke off. That would cause fuel line to FLOAT in the tank instead of lie on the bottom. This could easily be the cause of no fuel in primer/purge bulb. You probably need to:
Install new fuel filter..........Install new fuel Lines.......Install new primer bulb........Clean carburetor.
So in some respects, you are probably correct....no fuel filter equals bad fuel entering carb (but if none in bulb, doubtful much fuel (dried up maybe ) in carb.
Sep 06, 2011 | Husqvarna 28cc Gas Line Trimmer
Parts list and view for stihl bg55 blower
Unfortunately, STIHL won't release or allow their dealers to release illustrated parts lists of any kind. If you have a local dealer, sometimes they will let you look at their diagrams while at their shop. Sorry.
Dec 22, 2010 | Garden
Primer bulb won't prime
it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
Stihl hs 45 hedge trimmer primer bulb will not **** gas into it when pressing
trace the llines from the primer bulb and check them for leake it is sucking air from somewhere either the lines or the bulb
Apr 28, 2009 | Garden
Saws Logo
140 people viewed this question
Top Stihl Saws Experts
Joseph Mueller
Joseph Mueller
Spud Howell
ray gallant
Are you a Stihl Saw Expert? Answer questions, earn points and help others
