Question about Brother NX-400
Hi my machine will not sew when the needle is in the 1/4" position
5 Suggested Answers
  • 23 Answers
SOURCE: the thread on the brother sewing machine keeps breaking when the
You may have a snag on the plate. And that means a new one. Just one possibility.
Posted on Mar 08, 2010
  • 11 Answers
SOURCE: How do I fix thumping/clunking sound?
make sure your needle is facing the right way, some needles if you look at the front and back you will see a groove side and a flat side sometimes it is hard to tell the difference depending on needle style.. hold it up to light and look at it from the side the difference will be slight but you will see a difference groove should face the back or if your presser foot is out of wack (lol so technical terminology) it could cause needle breaks and noise you can detect damage to the presser foot if this is happening.... only other thing i can suggest is to make sure bobbin is securely snapped into the housing if not it can cause problems with the needle picking up the bobbin
Posted on Apr 08, 2010
  • 23 Answers
SOURCE: sewing machine 'popped', and needle is hitting
Adjust the metal plate to fix the needle hitting problem.
Posted on Apr 13, 2010
  • 1788 Answers
SOURCE: The needle on my machine appears to suddenly be
The needle needs to be replaced, it is not seated right
Posted on Aug 21, 2010
Needle locked in right position
Remove the needle holder using a tool suitable for it and remove the needle and fix it again in the correct position and continue the stitching in zig zag .
Thank You
Sep 13, 2008 | Husqvarna Viking 1
How to change needle position
Needle Positions on the SEWING MACHINE - YouTube
? 1:37
https://www.youtube.com/watch?v=OhN7w6DqX_Y
Oct 5, 2014 - Uploaded by Cindy Fetzer
8:52. How to Change Needle Position (filter bag machine) - Duration: 20:39. by Peter Wang 935 views. 20:39. BeginnersSewing Course - Day ...
Adjusting the default needle position, Brother PC 420 ...
? 6:53
https://www.youtube.com/watch?v=Xfq-GW88DsA
May 17, 2014 - Uploaded by Spamnot Nospam
Do you have trouble with the default left needle position making the needle of your Brother PC 420 sewing ...
Guide to Understanding Sewing Machine Needle Position
Jan 01, 2016 | Sewing Machines
How do you fix a left of center needle on a Morse Apollo 6500 sewing machine?
Is this machine new to you? Some of the older (but goodie) machines have a needle that defaults to the left. (I have an old Nelco that has this--great machine, just takes getting used to sewing with the needle in that position.)
Otherwise, I suspect the machine needs a thorough cleaning and oiling because the old oil may have dried out and is causing it to seize.
Jun 08, 2017 | Sewing Machines
Sewing machine sews good in center needle position, why does it not stitch,when moving needle position to right f left?
Hopefully it is a bent needle. Replace the needle first. If that doesn't work you will need an adjustment made on the hook. That is when you will need to take your machine to the repairman.
Oct 29, 2014 | Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
I just had my 7470 serviced because the thread tension was messed up. Now as I'm sewing along, the needle will move from center position to left position by itself and then within a few stitched,
the gear or part that holds the needle position in place may either
be getting jarred or is worn,,
try using a different threadThe needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
also try adjusting the top thread tension
as far as the bright spot, the display could be going out.
sometimes the repair person does not check the machine to
see if the machine is working correctly, because they would have
to charge more and some don't so you have to bring the machine
back more often and that makes them more money.
Dec 18, 2012 | SINGER 7470 Sewing Machine
My Bernina 1130 has zig zag problems. I have to turn my machine on for 10 minutes before it will even sew. When I sew straight it will skip a few stitches every inch or so. Now it will not zig zag mo
here are some suggestions
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
I really recommend having the sewing machine checked to
see if there is a internal problem, since you have to wait 10 minutes
before sewing & the problem with the zig zag & looping.
Oct 07, 2012 | Bernina Sewing Machines
Kenmore 158.1703 sewing machine - needle not going up and down
Sounds like your worm drive gear is striped and needs to de replaced. If you twist the handel on the end of machine does the needle move up and down.
Jan 03, 2010 | Kenmore Sewing Machines
Skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
May 07, 2009 | Juki DDL-8700
Brother NX-400 Logo
126 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
