Question about Kenmore 64802 Top Freezer Refrigerator
Water leaking from freezer onto top shelf of frig. has to be wiped once a day.
    Problem Solver:
  • 5 Answers
You probably have a blocked or frozen drain hole in the freezer. This means that the water formed during defrost can't drain down to the evaporator tray beneath the fridge and instead goes through overflow holes into the refrigerator.
I posted about how I solved this problem in another post:
http://www.fixya.com/support/t8706684-water_leaking_inside_refrigerator
Posted on Mar 19, 2011
Frigidaire frig. model#FGHC2331PF7 is dripping onto top shelf and the filter has ice cycles and what temp should freezer and frig be
If it's brand new and leaking, call the place you bought it from and have them fix it. As for the temp settings; there is a center default in the freezer and you should start there, the fridge also has a default which should be OK. If you need it colder turn it up in small increments and give it a day before you make any additional adjustments. The "cold" in a fridge or freezer also depends on how much stuff you have in the unit, and how often you have the door open.
Sep 08, 2014 | Refrigerators
Unplugged frig overnite once I plugged back in made a gurgeling sound whenever I opened the door what would that be?
Usually that is caused by a bad defrost heater thermostat or defrost timer. Failure to automatically defrost is the cause of freezing up.
If you don't feel up to doing the work yourself you should have an appliance repair shop look at it.
The gurgling is caused by water in the catch pan under the fridge. When you defrosted it some of the water made it into the drip pan (and maybe overflowed onto the floor). The fan inside the compressor area under and behind the freezer may be splashing in the excess water in the drip pan. This by itself is not a real problem since it is designed to automatically evaporate the water drained during automatic defrosting, but the excess water and potential overflow onto the floor can become a problem.
Mar 10, 2017 | Danby DFF8802 Top Freezer Refrigerator
Model #970658324 leaking water from the freezer to top shelf of frig once a week probably with defrost cycle. Help!
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Jun 04, 2012 | Kenmore Refrigerators
Water leaking from freezer box onto top self of frig. Has to be wiped once a day.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 11, 2011 | Kenmore Refrigerators
Hi I have A GE 18 cube frig model GTA18QBNBWW. Initially the food on the top shelf was freezing in the frig I discouver the coils were blocked by massive clumps of cat fur. i cleaned it out. next day i...
you have done a good job so far . so next ck the dampner at the top in the fresfood side . it may be stuck open causing the freezing . but the evap coil was frozen so you may have a heater out in the freezer so ck the defrost system heaters and defrost terminator . ..mm hope this helps feed back pls
Jan 19, 2011 | Refrigerators
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Water leaks inside fridge from top freezer
check your gasket on the refridge door see if it has any rips or you have a blocked drain in freezer
May 02, 2009 | Refrigerators
I have replaced my filter twice in the last month works fine for about a week then the funny tasting ice and water return
it is picking up odor and smell from the frig / clear frig and freezer / wipe down with vinegar and bleach and then add baking soda and a cup of sugar on top shelf or freezer and refrig and it should take care of the problem
Nov 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore 64802 Top Freezer Refrigerator Logo
438 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
