Question about True TSSU-48-12 Refrigerator Commercial
Fridge is getting to warm 43-45 degrees and then drpos in teperature to 31 degrees also water is dripping inside the fridge.
Water dripping inside KTLA22EMSS01
Your freezer actually cools your fridge. It sounds like you have ice build up in your freezer behind the back panel. You should be able to unscrew the back wall inside your freezer. A hair dryer should help defrost or keep it open for a few and use a screwdriver to remove the build up of ice. The ice has made its way down the vent and when it hits the fridge it is above 32 degrees so it is melting. Hope this helps. I manage rental properties and have had it happen on a few occasions.
Aug 16, 2012 | KitchenAid Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Water leaking daily from area below freezer, inside the fridge cavity. need to place containers to collect water and empty frequently.
sounds like outlet pipe is blocked at back of fridge unit, this is accessible from inside of fridge at the back and towards the bottom, remove any debris and feed through a relatively stiff piece of wire to unblock pipe, the idea of this is to take away excess water and feed it into a drip tray on top of the warm compressor where it then evaporates, however this can and does get blocked with food debris from time to time,.
Oct 26, 2010 | Whirlpool Refrigerators
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Ice maker quit working
check the teperature of the freezer compartment . the ice harvest actuates on teperature. and refill with water at the end of harvest cycle.. a lot of times the condensor under your fridge can become plugged with dust and the freezer teperature never achives low enough to harvest ice..good luck
Oct 06, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool ref in door ice not making ice
Sep 20, 2008 | Whirlpool GS6NBEXR Side by Side...
Freezer okay, fridge warm
i suspect a faulty defrost heater/thermostat or defrost timer. any other questions you can e-mail me @ hvac.tech7872pr@gmail.com
Jun 15, 2008 | Refrigerators
True TSSU-48-12 Refrigerator Commercial Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
