Question about Garden
I bought a stihl ms 660 chainsaw used with a 32 inch bar and chain. i ran it before i bought it and was good. then i started using it maybe 5-10 minutes and it died. i tried starting it again and took real long time and when it did start it didnt idle but died again. i took to repair shop and they said it was a scorched piston and cylinder. i paid $ 470 to get the piston and cylinder replaced. i was told by repairman to warm saw for about a minute before i go full throttle. i used the saw for about 3 tankfuls and the same thing happened again. i took back to repair shop and they said same thing happened and they are repairing it for free this time on the warranty. i use 89 octane fresh gasoline with ethanol, 50:1 oil mixture, and add fuel stabilizer. i was using echo synthetic blend oil and was told to use stihl high performance oil which i now do. what am i doing wrong? why is only one side of piston being scorched?
  • 95 Answers
They will score one side of the piston because of the heat.Its always on the exuast side.It could be the carb is adjusted to lean that makes it run hot.The muffler might need a good cleaning too?If it gets plugged up it will run hot too?It sounds like you gas and oil are mixed right.Thats about the only thing that will do it besides straight gas run in it.Could be the shop tec doesen't know how to adjust the carb?I would ask the to make sure its adjusted right.And not to lean.If its any kind of shop someone there should know how to do it right.When you get it back try running it wide open it should do whats called 4 stroke when not cutting wood then smoothe out while cutting.If you hold it about wide open and it runs fine.Its not right.If it does you need to open the high side of the carb a little.Maby a 1/4 turn at most.Just untill its getting to much gas to run smoothe.I hope they fix it right this time.Thats a very nice saw!
Posted on Mar 11, 2011
  • aheatseeker Mar 14, 2011
    thanks, ill try your advice. i bought the saw for $ 500 and thought it was a good deal but now im in it for 1000. brand new it goes for 1200. they are supposed to have it fixed beginning of this week. im dealing with the supposed best tech they have who went to stihl school. he is an older guy and seems to know what he is talking about. hard for me an amateur to tell him what to do. the previous owner said it was sitting in garage for past couple years. im thinking of also changing fuel line and carb and muffler to be on safe side. they had changed the fuel filter and put new gaskets on carb the first time. i really need the saw as i have a bunch of jobs to do and not much money until i do them. ill let you know what happens.
  • tbone75862 Mar 14, 2011
    You shouldn't need to replace the carb.The gaskets should fix it just fine.All long as the fuel lines are not hard or cracked they will be good also.The tech should clean out the muffler if he knows what hes doing.Sounds like he should.The muffler comes apart so he can clean the screen out.It will have some metal in it from blowing up twice I am sure.The screen is used for a spark arestor so it doesen't blow flames out of it.But it does have to be open for the saw to breathe right.Do let me know how its working.i will be glad to help best I can.
Need to know what kind of oil is used in 2.0 cid gas chainsaw?
Chain oil for the chain
STIHL Bar and Chain Oil - Chainsaw Accessories ' STIHL USA
www.stihlusa.com/products/oils--lubricants-and.../oils...lubricants/chainoi... Rating: 4.5 - ‎6 reviews Don't let friction cut down your chainsaw's performance. STIHL bar and chain oil is specially formulated to adhere to your chainsaw's bar and chain, providing ...
2 stroke oil for the engine
XP® Professional Peformance 2 Cycle Engine Oil 50:1 ...
www.husqvarna.com > ... > Accessories > Lubricants & Fuels XP® Professional Peformance 2 Cycle Engine Oil 50:1. Our best ... 610 00 01-31, 6.4 oz. bottle for 2 1/2 gal. mix (50:1 Mix), $ 3.29. 610 00 01-32 ... Chainsaws.
Oils and lubricants STIHL
Feb 08, 2016 | Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
What oil please
Best to use proper chainsaw oil to lubricate the chain cutting in the wood, but at a pinch you can use multigrade car engine oil. Don't use secondhand oil as the added acids,pollutants, etc., from the engine will break down the oil making it less efficient....and leave staining on the wood.
Chainsaw oil can be readily bought from good garden centres.
Hope this helps.
Jul 14, 2014 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chaisaw oiler on ms390 stihl is not working
Take bar and chain off and ensure oil feed is not plugged also use only stihl bars
Feb 11, 2013 | Stihl Hand Guard Chainsaw Ms 290, Ms 310,...
Have an 029 farm boss with 16 inch bar upgraded to 20 inch all was checked and bought from a stihl dealer they even put it on. went home used it for about 15 min and the bar and chain went dry no oil going...
It sounds like you may have something stuck in the oiler port or groove of the bar. You can use the pointy end of the chain file guide to clean the bar out and give it a shot again.
Good luck
Mar 30, 2011 | Stihl Chainsaw 024 026 Oil Pump
Chain jumps of bar when starting to cut.
check to make sure that the chain tension is correct. when tightening the bar bolt nuts - lift up slightly on the bar as you tighten the nuts,, and then check the chain tension of the chain.
if you pull up or down on the chain - it should only rise about 1/8th of a inch off of the bar when you pull and snap back into place when you release it.
one other thing to check -- make sure the bar groove is clean and clear of dirt and debris ( use a bar groove cleaner or a small flat blade screwdriver to clear out ).
and,, check the chain to be sure that none of the guides are bent or mis-shaped.
happy cutting,
c...
Jan 07, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
May 09, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Oct 26, 2009 | Garden
Chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Oct 01, 2009 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
438 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
