Question about Panasonic DMRES30V DVD Recorder/VCR Combo
Samsung VCR recorder has noise least displaying lED lighting also malfunctioning. An aready existing answer was check on 1c1 fuse that is blown. The questinon is requesting to resolve devices lED screen also with diagrams making revival attainable.
    Novelist:
    Champion:
  • 347 Answers
Try the new firmware it will reset the whole unit this should work
Posted on Mar 11, 2011
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
21-1C1
Error 21-1C1 Failed to complete the reel position movement within the Cassette tape in specified time. will be ejected.
Jul 10, 2013 | Sony HVR-1500 HDV VCR
Toshiba DVR610 suddenly will not power up, no lights, no sound, nothing. Any ideas? Thanks.
Check the fuse and diodes. If fuse is not blown check for open resistors in the power supply area of your DVR. The problem will most likely be in the power supply section of your DVR
Aug 13, 2010 | Toshiba DVR610 DVD Recorder/VCR
Hello i have a omt 1987 1015 lights power up but will not play when you select led shows record to be playing but does not play will not show credits or house hits have checked all fuses none blown have...
Is your 3 digit display on? If not, does the Z LED Flash when rotating the record carrier? If so, you may need to have your computer repaired. If the Z LED doesn't flash, check the 12 volt fuse in the amplifier. If you need your computer repaired or further assistance, please email me, Rod Stebelton, tech@wurlitzer-ohio.com.
Dec 27, 2009 | Wurlitzer Jukebox 1015 One More Time...
Dash lights for odometer and shift display don't work
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi! My friend,
I have similar problem. The LED light for gear information plus odometer won't shine on. I took
action to access the package containing the impacted part. I found out the problem originated
from the loose contact somewhere inside the package. The way I sorted out this real problem is
to squeeze/bend the plastic package; then, the LED light will show up and go off if loosing the squeeze.
This problem came from poor QA in GM Purchase. Somehow, the electronic connection became loose
after frequent vibration or owner usage during years of auto driving. If GM can't guarantee its QA, its
design should not bind an auto owner to make expensive amount for just one or two LED malfunction.
Wish this finding can help your problem.
your friend
Jul 29, 2008 | 2002 Buick Century
Samsung DVD-V4600A Combo DVD / VCR will no longer timer record to Videotape
Storms tend to fry most delicate electronics. Quality surge protection is required.
Ben
Jul 25, 2008 | Samsung DVD-V4600 DVD Player/VCR
Display problem
You have problem with the psu.Three capacitors 820mF/25V are dead and there is a fuse 3A worn out
May 19, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Panasonic Video Recorder has stopped working
looks like some kind of sensor within the mechanical part, its seems like the mechanism doesnt return fully to its original point giving you these kind of malfunctions, I suggest to take it
to an authorized dealer for a complete check up & tune up
Apr 15, 2008 | Panasonic NV-HS1000 S-VHS VCR
Panasonic VCR PV-4652
If the MFD (Multi Function Flourescent Display is not working, check the -27 - 30 Volt (minus 27V to minus 30V) supply line. The fuse or a fuse resistor (around .5ohms 1/8W ) will be blown.
Also, it is possible that the 3V AC heater supply line is disconnected at some point.
Check that also.
Apr 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Panasonic DMRES30V DVD Recorder/VCR Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
