I got a Dmtech dml-4132wd television. After I plugged the A/C power cable, i got a red light on the power button of the TV, and then i tried to turn it on, and here is the problem. The red light keeps flashing, and i can not see anything on the screen.
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
SOURCE: th-42pz700u
Same problem. Have to wait until they open back up tomorrow to make the call.
Posted on Dec 11, 2007
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
  • 5 Answers
SOURCE: Power to TV, cant power on, red light flashing
The repetitive blinking light is a trouble code which is used to determine which series of boards may need to be replaced. How many times does the red light blink?
Posted on Aug 30, 2009
My dmtech tv/dvd flashes on the power button when I plug the power adapter into the tv. Sometimes it turns on other times it just flashes. Please help
You have an intermittent situation, the bane of all DIYers and normal repair people. Till it goes completely you might just want to check out the power supply of unit.
Nov 22, 2015 | Televison & Video
I have no power with my tv
Hi i have a dmtech tv lq20xtv it takes a long time to come on sometimes 45 mins the red light standby is on nothing else happens any solutions is it worth fixing???????
Apr 29, 2012 | DMTech DM-AV10 Digital Media Player
Tv will not turn on anymore. when you press power button the light turns greennand the red light flashes at the same time. then nothing
This is more than likely a main board issue.
Try a mains reset. -Remove all the cables from the TV and unplug from the wall -Press and hold the power button on the TV for 30 seconds -Plug back in and try and power on
If this fails seek an engineer for a repair.
Apr 25, 2011 | Televison & Video
My dmtech tv when i plug it in and switch it on, which is located under the tv. then the little lcd light comes on . when i click the button it starts to go of and on and tv does not swich on it just stays...
RE. the fault on DMTECH TV that doesn't turn on despite the lights on the panel going on and off intermittently - did any post a solution? I have the same problem.
Dec 13, 2010 | Televison & Video
I have a DMtech LCD model LV19XTM - the power adapter shows a green light unyil it is plugged into the back of the TV then the light goes off and no power is getting to the TV - is this an adaptor problem...
is this the original power adapter or a new one. If it's a new or different power adapter, it could be the plug configuration on the new power adapter is different, as i had the same problem, but was able to fix it
Oct 19, 2010 | Televison & Video
My dmtech tv will not turn on. the light is on the
I have same problem, did you manage to get anywhere? deskeech@ntlworld.com
Jul 20, 2010 | Televison & Video
Missing power lead DMTECH
If the plug has three prongs and shaped like a flat top pyramid a standard computer style cable will work. If not draw the shape best you can of the plug and go to a local repair shop or electronics store and they may be able to help. Alot of these cables are interchangable.
Sep 04, 2009 | Televison & Video
Blinking red lights
Take out all the cables (HDMI,POWER,RCA,etc...) and then plug just the power back in and see if the TV turns on, and make sure when you take the power cable out, take it out from the back of the TV, when you plug it back in it should click.
If the TV powers up then try plugging in your HDMI cables and see if that works.
May 25, 2008 | Televison & Video
DVD region playback error
Went into the settings menu, searched for the 'default' tab and reset setting to default & hey presto....all ok!!
Simple when you know how!!
Apr 21, 2008 | DMTech Televison & Video
Power supply for dmtech wt20xt lcd tv
I have DMtech 20" with intergrated DVD and had the same problem- blue light lit on power switch but no response on power up.
I noticed that when the power cord was unplugged from the back of the TV the green LED on the power supply would brighten and consequently dim when plugged back in. Sometimes the blue light on the power switch would strobe very quickly but you had to look carfully for this.
I repeatedly unplugged the DIN type power plug from the back of the TV untill the green light on the power supply stayed a constant bright and there was no strobing on the blue light on the front of the TV, when I powered the TV on at this point the button worked again and the tv powered up with the silly tune then life in the screen. I did have to do this a good few times (I'm tenacious) but it did work!!!!!
Hope this helps someone else, cheers.
Apr 11, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
