Question about Hoover UH70205 WindTunnel TSeries Rewind Plus Bagless Upright Vacuum
Hi, I have a Hoover windtunnel t series vacuum. It was working fine until the last couple of times I used it. It just does **** uo the dirt. It **** a little, but not as strong as it used to be. Already checked for clogs (didn't find) and cleaned it and still doesn't work. Any ideas? Thanks!
  • 694 Answers
This model, along with some similar ones, has been recalled. Stop using immediately. See the following site for information.
http://www2.wsls.com/business/2010/may/28/recall_hoover_upright_vacuum_cleaners-ar-362266/
Posted on Mar 12, 2011
Do i need to let the filter dry before using my hoover bagless hepa vacuum?
Yes, make sure it is completely dry. Other wise, very fine dirt will be much more difficult to remove.
Nov 28, 2010 | Hoover S3755 WindTunnel Bagless Canister...
Suction not working on vaccuum.
Check for a blockage in the hose, or a tear / hole in the hose between the "pleats"
Jun 13, 2010 | Hoover U5753-900 WindTunnel Bagless...
I have a Hoover Deluxe Elite Rewind w lifetime Hepa filter and automatic rewind cord 24ft. but recently it is not vaccuming as sufficent as it did last time used, which is once per week. I do not see where...
make sure the hose is installed in the foot when using for the floor. check the belt. when working properly, you should see dirt spin in the dirt cup.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Sep 27, 2009 | Hoover U6630-900 WindTunnel Bagless...
Left side of Hoover Windtunnel won't pick up dirt and hair
Take it to your local vac shop for repair. They can help you. It needs to be serviced annually anyway to perform properly.
Aug 07, 2017 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel has no suction
SOUNDS LIKE A RESTRICION IN THE INLET PORT CLEAN IT OUT
May 03, 2009 | Vacuums
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dirt cup lock on windtunnel vacuum won't lock
It may have to be taken off and then re-installed, but if it is only 1 and 1/2 old, then it is under warranty. There is a full year on Hoover vacuums. Just take proof of purchase with you and take it to a warranty repair shop. You should have their 1-800 to call and find the closest shop. Warranties are void if you temper with it.
Nov 10, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
Mine does the same thing. There is no suction. I found that there is a door that opens when you tilt the handle in the down possition. I think there should be a spring in place so it can open. Until I find a replacement spring I have to open the door manually throught the opening under the light.
Oct 15, 2006 | Hoover U6630-900 WindTunnel Bagless...
Hoover UH70205 WindTunnel TSeries Rewind Plus Bagless Upright Vacuum Logo
260 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
