Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
I have a powershot SD 790 IS.When i turn the camera on i get the message Card locked.How do i get it unlocked & can my pictures still be recovered? Thank-You Maurita reit_24@yahoo.ca
    Guru:
  • Canon Master
  • 1,705 Answers
Take the card out of the camera, on the left hand side, you should see a small notch you can slide to lock and unlock. Slide to the unlock position.
If its already in the unlock position, re-insert it and check the camera - card setup menu, you may have picture protection enabled..
Once accessed you will see which pictures have survived, the only problem I can fore see is that you tried to take pictures while the card was locked, in this case, none will survive.
If you think there are files which may have been deleted, you could download and install "recuva" from "filehippo.com" then try to recover deleted files, but be sure to recover said files to a new destination ie a folder on your PC. If you recover back to your card, you will overwrite the very same files your trying to recover.
Posted on Mar 11, 2011
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
My camara has a display that says Card locked >
There is a slide button on the side of the card. One direction locks, the other unlocks. If this doesn't work, make sure you didn't buy an SDHD card for a camera that only uses SD. The error message shows if it's the wrong card. That was my mistake last week.
Nov 20, 2010 | Canon PowerShot A560 Digital Camera
When I turn the camera on, a message appears on the screen saying "card is locked". Can't take pictures or operate the camera.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 18, 2010 | Canon PowerShot SD850 IS Digital Camera
Camera says that my sd card is locked and it isn't
try to put some glue on a your card lock , in unlock position. But be carefully do not delete your picture by accidentally.
May 31, 2010 | Canon PowerShot A710 IS Digital Camera
How do i get the card lock message off of my powershot a480?
Apr 30, 2010 | Canon PowerShot A480 Digital Camera
I have canon sd 790 is camera and shows "card locked" laszlo.kenderes@gmail.com
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 15, 2010 | Canon PowerShot SD790 IS/ IXUS 90 IS...
My Canon Powershot A560 memory card is locked and it is the camera doing it not the memory stick. When I turn on my camera I get an error message"memory card error" then when i press to view pictures it...
Turn the Canon Powershot A560 over so the bottom is facing up.
Locate the door on the bottom of the camera. The door is labeled "CARD/BATT. OPEN."
Place your thumb on the slider on the door. Push the slider up to unlock the door. Then, slide the door out to open it.
Find the SD card. Inside you will see four batteries and the tip of a small plastic disc. This plastic disc is the SD card.
5
Eject the sd digital memory card. To eject the card, gently push on it and then release the pressure. The SD card will pop out part way. Go ahead and pull out the card.
6
Turn the card so the writing is right-side up. On either the left or right side of the card, you will see a grove with a tiny plastic switch in it. If the switch is at the bottom of the groove, the SD card is locked.
7
Unlock the SD card. Using a fingernail, slide the switch to the top of the groove. The card is now unlocked.
8
Return the SD card to the camera. Place the card in the slot and push down until you hear a click. The card is now successfully reinstalled. Do not worry about inserting the card the wrong way, because it will only fit one way.
Nov 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
How will i unlock a memory card in SD 790 IS canon camera
All SD (and SDHC) cards have a locking switch on them and this can be activated accidentally when handling the SD card.
Remove the SD card and slide the switch on it away from the lock position. If this does not work or if the switch is already in the correct position, then slide it all the way to lock and then fully back again.
If this fails then you have a faulty SD card and must replace it. Dirty electrical contacts do not result in a card locked message so you won't have to worry about those but as with all memory cards never touch the contacts unless they clearly need cleaning. Note that if you have to replace the memory card you can use regular SD cards up to 4GB and SDHC cards which start at 4Gb rising to 16GB maximum. The camera slows down when using SDHC above 8GB though.
I hope that you have found my answer to be of use and in return I ask only that you rate my answer.
Oct 22, 2009 | Canon PowerShot A620 Digital Camera
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
Canon a590 Card (not really) Locked
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Jul 23, 2009 | Canon PowerShot A590 IS Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
174 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
