Question about Eureka 431A Optima Bagless Upright Vacuum
My eureka optima upright bagless vaccum has VERY low suction using the floor part. the hose has excellent suction. i removed the little translucent door underneath and there were no blockages, i cleaned the brushroll thoroughly and that hasnt helped either. i know this probably isnt recommended but i turned it on to the floor setting with the brushroll off and stuck my fingers up the intake as far as i could, the suction was good further up but it just seems to stop down at the base. because i stuck my fingers up there from the bottom of the machine and could feel sufficient suction i'm not convinced that there is a blockage. help!!
  • barnswallowv Mar 22, 2011
    yes, the plate seems to be on properly and i can't find any cracks at all.
    President:
  • 1,654 Answers
I will try and help here. Is the sole plate on the bottom of the vacuum complety on and there are no visible cracks along the seam where it meets the body? This is the usual cause for this. Onc you take of the plate to access the roller and brushes, if this is not put on correctl you will lose suction. Look for any other openenings that can cause a air leak.
Posted on Mar 20, 2011
  • Dcramer531
    Dcramer531 Mar 20, 2011
    http://www.eureka.com/service/manuals/75...
    here is a link to the service manual for this machine What I called the sole plate they call the base plate, but still the same .
  • Dcramer531
    Dcramer531 Mar 22, 2011
    On these vacuums, they are very simple so either the loss of suction is from a dirty filter, blockage or the base plate. Since your telling me that your getting good suction up in the top part of the base, then the loss has to be coming from a bad seal around the plate. There is simply nowhere else for the loss to come from. This vacuum has had a lot of revues and a lot of complaints for the loss of suction, most of these were attributed to the filter system and how little dust it actually takes to start seeing this issue. My guess on this is that there is a good air flow your feeling but the actuall suction volume is not sufficiant. There is a big difference in flow verses volume, good flow does not mean sufficiant suction volume. This vacuum perfoms suburbly when they are new but tend to lose suction from day one and it gradually decreases till we get were we are today. If you are confident that there are no obstructions and the base is on correctly and tight, then a new filter is what you will need to get this performing like it did when it was new. The filter is designed to be cleaned and reused but it must be at the end of its cleaning life.
    President:
  • 1,961 Answers
Hello!
There is an obstruction on the airflow.
You might consider looking at the translucent door again that you removed.
When you put it back again, did you try to examine closely that something may be blocking or jamming the door during the operation of the vacuum.
Try again what you did, when you turn on your unit and put your fingers inside it, but this time make sure the translucent door is put back in its place before turning the unit on. See if the door opens when the vacuum started to work.
Posted on Mar 11, 2011
Hi I have a Eureka upright bagless vacuum and I need to use the hose attachment to vaccum a car seat and floor. How do I get the suction to apply to the hose only?
Look at the top of the plastic housing that covers the brush roller. You will find an adjustment lever that switches from floor to hose. The lever may be difficult to move. It is not a feature of Eurekas that ages well.
Feb 01, 2017 | Eureka Vacuums
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
My Eureka Optima vacuum doesn't have any suction when on the floor option. How can I fix this?
It will as long as long as your accessory hose is properly inserted into the base. Otherwise the vacuum stays on the hose only.
Mar 13, 2010 | Eureka 431A Optima Bagless Upright Vacuum
Very little suction? Someone give me an answer please.
You must have something obstructing the airflow. There is sometimes a small trap door under the vacuum where the brush is located. Open that door and see if there is something jammed in it. If you don't have the door, then there is an obstruction somewhere in the vacuum. You should also look in the hose.
Jim
Jun 10, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Eureka Optima vacuum has suction at the hose but not at the floor. I took out the filter and it still isn't suctioning so I don't think it is the filter.
it sounds like you have a plug. check where the hose goes into the back of vac. it should have a clip remove this and see if there is a plug there
May 18, 2009 | Eureka 431A Optima Bagless Upright Vacuum
No upright suction
This means that you have something plugging the main camber where the dirt enters through beater bar head.check that out. biigg53566
Jun 24, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka Boss - no suction in upright postion
when mine does that I find that the hose is not connected properly where it comes off to use the attachments.
If there is suction there, it is a straight shot to the floor unless it is loose where it fits together.
Jun 04, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Hose suction Eureka theboss smartvac
There has to be a clog in the hose, Unhook the hose and drop like a big marble in it to see if it comes out the other end.
May 10, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka 431A Optima Bagless Upright Vacuum Logo
115 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
