Question about Hannspree HW191D LCD Monitor
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could be i need my monitor working :(
    Sergeant:
  • 146 Answers
Here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Posted on Mar 11, 2011
Testimonial: "This could be help to me but im sure its not the CPU"
  • 1 more comment
  • cliffords636 Mar 11, 2011
    I cant really explain it properly but all it was is it was working last night and when i turn t it on this morning just no display picture it goes to display it but just says "no signal check connection" but i noticed the power cable in the monitor isnt that stable and the slightest nudge can cause it to loose power and sometimes it sparks, could it of blown something you think? also when i turn it on and off it makes a little noise when its checking connection then just goes straight to standby its deffo the monitor cause my tv works and so does my old CRT
  • Andik Fitriansyah
    Andik Fitriansyah Mar 12, 2011
    does you change the screen resolution last time?? :D
    it mean your LCD not compatible with high resolution
    here my suggestion
    1. boot with safe mode
    2. change the screen resolution at display properties.
    3. reboot
    thanks using fixya.
  • cliffords636 Mar 12, 2011
    thing is it dont even show the bios loading up or nothing so i dont know if i am safe mode unless i go through the Tv and change it ??
No DVI video output from dell xps 210
It sounds like your video card has gone out. Is the VGA and DVI ports on the same video card? If so the card is probably bad.
Mar 25, 2012 | Dell XPS 210 PC Desktop
Hi there basically I have two ports on my monitor dvi and vga and dvi is connected with another appliance so that leaves me vga but when I connect my vga to my desktop the computer is on but there is no...
try with DVI port and see it works or not.
if worked buy a converting port (DVI to vga) and connect you video card Via DVI
and connect your other appliance Via VGA port by that converter.
Jan 09, 2011 | Computers & Internet
The complaint for this DELL E152Fpb LCD Monitor was when switched on has power (LED lit) but no display ti goes yellow on the power led but it brings no display on the screen.
It is standby mode, no signal, It is possible that your computer is not POSTing.
Connect your screen to another computer/laptop, just to make sure, which component is not working. Either the Screen or the Computer.
Make sure the DVI/VGA cable is firmly connected as well as RAM modules and Graphics Card.
Please take the time to rate my expertise.
Thanks
Nov 01, 2010 | Dell E152FPb 15" TFT LCD Flat Panel...
Cant use TV as Computer display
If you can disable the blue screen via the tv menu you might see something happening behind that blue ,you might be able to figure it out from there, also try to connect as directly as possible (tv/computer) even if you have to physically move one or the other, that way you can eliminate possible problems. good luck
Nov 03, 2009 | Samsung DynaFlat TX-P3064W 30" TV
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Using external monitor with Vista
the problem with adapters is they dont always pass all information thru,,try changing the screen resolution on the laptop down a little
Sep 18, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Hannspree HW191D LCD Monitor Logo
598 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
