Question about Brother HL-2070N Printer
Trying to assign a static IP to a Brother 2070n printer. Can anyone point me in any direction? Thanks in advance!
    Scholar:
  • 172 Answers
You can find step by step configuration from the below link:
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000360/HL2070N_NUG_ENG_1.pdf
Please rate this, if you like soution
Thanks
Sandeep
Posted on Mar 11, 2011
Printer will not stay connected to the router. Everyday, someone tries to print to it and it shows as offline. I have to go in and set it up daily. Is there a setting to keep it online?
By router, I presume wireless connect between it and the printer?
Will your router support static ip addresses? If it will assign one just for the printer. Then turn the DHCP
client software off in the printer and assign it the static ip from the router. Should solve your problem.
Mar 22, 2011 | Brother MFC 6490CW InkJet Printer
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
Sometimes i try to ping the wireless access point and i get the message 'Request time out',i receive this message even if im directly connected to the access point.what should i do
When you connect the computer directly to the access point, you might not be getting IP address on your computer.
You will need to assign a static IP address on your computer in the range of default IP address of the Access point.
Click Here for More info on access point
Oct 08, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Network issue with Brother 2070N Laser printer
Check if you have disconnect the USB Cable. Get IP from the printer in the menus. If you can´t get it. Use a Program like MarkVision Professional. You probably have no DHCP in your network. you should enable it and check IP in the router.
Jun 22, 2009 | Brother HL-2070N Laser Printer
When installing Brother Network Printer undetectable
You have to know the IP Address of your printer before using it on the network. Once it is connected to a LAN, go through the printer menu - network setting - IP and print it out. With this you can publish the address when prompted ok. Or simply attach it to a pc and share it over the network. However, the pcs must be in the same workgroup or domain so as to see themselves. Good luck
Apr 28, 2009 | Brother HL-2070N Laser Printer
Oki3400n - how to assign a static ip address
I found this post via Google trying to solve the similar problem with C3200n.
>> this will then cause problems as all the pcs that are trying to print to this
>> printer will no longer be able to find the printer.
Originally, I also had this problem (with C200n, but it is probably similar). If I recall correctly, I solved it as follows:
1. Open the OKI LPR UTILITY from the machine you are trying to print from.
http://img8.imageshack.us/img8/4552/okilprutility2009080217.png
2. Choose Option > Setup
http://img8.imageshack.us/img8/9641/setup20090802171057.png
3. Make sure that the Auto Reconnect checkbox is checked.
Again, I believe that is what I did to solve that I couldn't print after power outages etc. The IP is not static, but it still solves the problem.
Static IP
Today I wanted a static IP for my OKI C3200n because sometimes there would be conflict between the IP for my printer and another machine in the house with a static IP.
What I did was the following.
1. In the printer menu locate the NETWORK MENU
http://img35.imageshack.us/img35/6889/dscn0525e.jpg
2. Go to the IP ADDRESS SET option, change from AUTO to MANUAL
http://img25.imageshack.us/img25/6122/dscn0526x.jpg
http://img195.imageshack.us/img195/7987/dscn0527j.jpg
3. Go to the IP ADDRESS OPTION, change to the desired ip address. In my case it was at 10.0.0.5, but I wanted 10.0.0.6 for the printer, so I changed it to that. Typically this is either 10.0.x.x or 192.168.x.x
http://img35.imageshack.us/img35/4407/dscn0528p.jpg
http://img90.imageshack.us/img90/1669/dscn0529r.jpg
4. Press the online button. The printer will reset the network connection (it took approx 1 minute)
http://img195.imageshack.us/img195/2539/dscn0530.jpg
5. This should be enough. You can try to ping the printer at the new IP, or navigate to the new IP in your browser:
http://img44.imageshack.us/img44/565/c3200nopera200908021755.png
Feb 01, 2009 | OKI C5400 Laser Printer
Brother HL-2070N Will Not Print
Hi tom8972
try to reinstall the driver of it.
hope this helpful for you,
thanks,
Hamedo
Sep 13, 2008 | Brother HL-2070N Laser Printer
Brother HL-2070N won't feed paper from tray
I had the same problem with 2 of the 2070N printers. Solution was that the paper tray was setting to tight against the paper pushing it tight up to the front of the tray. Back the rear support up so there is maybe 1/16 inch clearance between the paper and the end of the tray. No more feed problems.
Jun 04, 2008 | Brother HL-2070N Laser Printer
Ip assigning
hello!
-- what is the exact model number of your router?
-- the ip address that you are trying to assign to your router, is it provided to you by your isp?
-- what is your nrtwork setup?
1. try to reset the router and try again to assign the static ip address.
2. make sure you will input all ip address correctly including the subnet mask, gateway and dns numbers
3. if its still not working try to upgrade the firmware or software of your router, maybe its corrupted thats why its not accepting the settings
Apr 28, 2008 | Lucent CellPipe 20S Router
Brother HL-2070N Printer Logo
386 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
