Question about Microwave Ovens
Geting E3 message on display after switching it on Pigeon rapido touch
    Brigadier General:
  • 8,909 Answers
E3 means faulty control board.
Posted on Mar 11, 2011
I need I know how to set the clock on an lg microwave model ms1446sqp
The MS-1446SQP is the version of this microwave sold in Mexico. To set the clock, press the button labeled Parrar/Borrar (Stop/Clear on English microwaves) in case any cooking programs are running. Then press the button with the clock face (Reloj). Then press the touch pad labeled Inicio/Inicio Rapido (Start/Fast Start). Type in the 4 digits of the current time (24 hour format). Then press Inicio again. (Note: I have left off the accents.)
The manual for the LG MS-1446SQP is available here: http://www.lg.com/mx/soporte-producto/lg-MS-1446SQP . The directions for setting the clock are on page 12 (pictures of the control pad are included). This is the Spanish version of the manual and is a pdf. Thus you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 18, 2012 | Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Pigeon Induction Error E6 occurs
E6 stands for 'Internal Electronic Temperature is higher than normal for 3 seconds', contact service centre.Source: Prestige Induction Error Codes
Feb 16, 2011 | Microwave Ovens
E3 Displayed. Cant select functions and continuous beeps.
That is probably the touch pad or control board that is faulty. Replace the faulty part.
Feb 10, 2011 | Microwave Ovens
E3 error message on prestinge induction Cook. Not able to do any operation, as soon as we power on the cook, it goes to E 3, It is only 3 hours old. Please help me.
E3 generally means a control board error.
If it didn't get damp with steam from cooking, take it back and exchange it.
Hope that helps.
Jan 24, 2011 | Microwave Ovens
Microwave Model 40180089700 shows "5E"
You have an error code and probably for good reason. maybe a switch is bad to keep out radiation for closing the door or what ever . If you don't know about these things don't mess with them! They are very dangerous and it can radiate you with out you knowing in some instances. Not worth messing with ,too dangerous for the unknown guy!!!!!
Jan 12, 2011 | Kenmore Microwave Ovens
Just show error E3 and does not work
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault.
Hope this helps.
Jan 03, 2011 | Microwave Ovens
Hi I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3...
I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3 and nothing else works.
In order to start it again I have to switch off the power and start all over again.
Please help me in fixing this problem
Oct 28, 2010 | Microwave Ovens
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Microwave Ovens Logo
77 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
