Question about Ricoh Aficio 1035 Copier
I have aproblem sc402 when westart button tomake copy
  • 263 Answers
That is a current leak in the Transfer Unit.
At best, maybe something is out of the place (on the transfer unit like transfer roller)
However i advise you to call your provider because it can be a High voltage Supply board defective or a Transfer Connector cable defective.
In any case i advise you to call a specialized technical support
Posted on Mar 11, 2011
Error code on display. Sc402. what does the error
Transfer problem
Your Transfer unit disconnected or bad connection.
Unlikely, but a transfer power supply could be faulty.
A piece of paper stuck in the transfer area could also cause that code to come up.
If the machine is dirty and you see toner all over when you open the right side of the copier, have it cleaned thoroughly, that will most likely solve your problem.
Aug 24, 2011 | Ricoh Aficio 120 Copier
Tip
How to elminated sc402
some times transfer unit current didn't receipted charge properly there is two springs charge transfer unit if one of both out of position may causes sc402
on Apr 23, 2011 | Office Equipment & Supplies
Fuctional problems sc402. ricoh aficio 150
SC402: Transfer roller leak error 2
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
  • · High voltage supply board defective
  • · Poor connection of the PCU
  • · Transfer/separation unit set incorrectly
  • · Transfer roller damaged
Jan 26, 2011 | Ricoh Aficio 150 Copier
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
Car stereo displays 000ZAA
000ZAA:
remove front panel and press reset button with ballpen
Jan 10, 2009 | Car Audio & Video
I have a Lemark Printer series 3500-4500 have aproblem with printing Pictures what can I do
my printer will not copy what i want to copy . i have tried to copy something new and it keeps going back to what i copied a week or two ago . iv'e canceled and tried every thing i know . very disgusting. help .
Jul 31, 2008 | Office Equipment & Supplies
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Fault code SC402
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 1035 Copier Logo
56 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
