Question about Philips Televison & Video
Tv will come on the blue light blinks but will respond,i get 6 long flashes and 5 short flashes.
  • 325 Answers
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)! The backlight inverter is what lites the screen for viewing!
I would recommend to repair immedately and stop trying to turn it on over and over...this will futher damage your tv and cost more to repair in the long-term.
Please rate if this helps! :D
Posted on Mar 11, 2011
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Phillips tv no pic no sound just flashing light
Its not going to be a do it yourself repair--likely a bad board or even boards--have a repair center (authorized for this brand) inspect it.
Just getting a set like this apart safely is tricky.
Apr 29, 2012 | Televison & Video
Goog day. I have a Samsung LE40A559 LCD TV and about a week ago it stopped responding to the remote. Remote itself is working as when the TV is off and I push buttons on the remote the blue light on TV...
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed.
Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
Nov 05, 2010 | Samsung TV Remote Control
What is the code for philips tv using RCA universal remote control ??
just follow the steps below
1. Manually turn on the TV.
2.Press and hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then release the CODE SEARCH button.
3.Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
4. Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
code list for philips :
003, 004, 008, 012, 019, 062,068, 069, 075, 076, 086, 087, 088
5. Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
6.With your TV on, press CH+. If the TV responds, no further programming is required.
if it works ignore the following thing (quite difficult and irritating one)
1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH.
2. Press and release the device button for the device’s code you are retrieving (TV). The INDICATOR
LIGHT will blink once then remain lit.
3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
if you want code list for all devices
download this pdf
Jun 14, 2010 | Televison & Video
Try to turn on, it turns off right away and the stand by light flashes 6 times
Hi
Thanks for using FixYa. Standby/Timer light blinking 6 Times means no Horizontal (H STOP), no raster, and so the set goes to the blinking self-diagnosis function immediately. You’ll need to open the back off the TV and check C515 & 516 and the jungle IC, IC206. Also check +5 line is overloaded (A, B boards), +5 line is shorted (A, B boards). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Oct 30, 2008 | JVC HD-61Z575 61" Rear Projection...
No picture
can you please mention your tv model
Jun 12, 2008 | Sony FD Trinitron KV-32HV600 32" TV
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
