Ricoh copier 4022 sc542 sc548 error codes after changing with photo conductor unit type 1027,
  • 34 Answers
If I'm not mistaken, that type of photoconductor is not compatible with your particular model of machine. The SC542 and SC548 errors are related to the fuser unit. It is not warming up correctly. It could be that it needs replacement thermostats or thermisters. It's possible that the incompatible drum unit has created this problem.
Posted on Mar 12, 2011
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Sc542
Press Clear(yellow)key then press 107 press and hold Stop/Clear(red) key more than 3 second select SP modes,open a front door,turn off the power switch,wait 2 minutes,close the front door and turn ON the copier.
SC 541-542 fuser unit thermistors or thermofuses malfunctions.
Jan 22, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Sc542 code
Try to reset a Level A SC, by entering SP 5-810 (SC code reset) and selecting
"1". You should hold down the Photo mode key and the # key at the
same time for 3 seconds. Try and see if this problem will appear again.
May 11, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Tenho problemas na minha fotocopiadora Ricoh 1027,aparece no ecram código SC548.qual saida para situação
SC548: Fusing unit set error
Symptom: The machine does not detect the fusing unit.
Possible Cause: • Poor connection of the fusing unit
• The fusing unit is not installed
Jan 09, 2011 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1045 only one copy printed then error code sc 342 will seen
Hi, there's no sc342 listed in the service manual, and I've never seen that code in years working on these machines. Are you sure it's not a different code, like sc542?
Sep 14, 2010 | Ricoh Aficio 1027 All-In-One Laser Printer
MY RICOH AFFICIO 1027 JAMMED AND SHOW SC542
SC542 A Fusing temperature warm-up error The fusing temperature does not reach the standby temperature within 20 seconds after the main switch is turned on. • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermostat open • Power supply board defective • Poor connection of the fusing unit
Apr 16, 2010 | Office Equipment & Supplies
Ricoh 2045 error code SC350
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Dec 04, 2009 | Ricoh Aficio 450 Copier
My Ricoh Aficio 1027 has a fuser code SC542. Is there a way to reset this in service mode (I know how to get in) to continue printing or will I need to replace or repair a part? The copier no longer has a...
to reset it just enter service mode and cycle power. But first take out the fuser ( right side of copier 2 screws ) and check that the 2 rollers hot and pressure are touching each other no gap between them. The unit you have is a nice unit, for service to fix if replacement is required would be about 300.00 or so... -Carl
Jul 24, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Jan 07, 2009 | Ricoh Aficio 450 Copier
Error sc548 on a ricoh 1027 just did maintenance must of turn on before fuser installed , how can i reset?
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working
Jun 17, 2008 | Office Equipment & Supplies
235 people viewed this question
jasbo
jasbo
