Question about Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive
I have a 6L300R0 hard disk, i brought it set it up got running at 300gb as expected after a short time i had a problem with cross-linked files which i had to relinquish. I deleted the drive which was on the disk at the time including erroneuos drive`s which i did on Partition magic and now i am only left with 32gb. I have got the jumpers in the right order, iv`e tried the disk to computers for bios problems, i have used Maxblast with a low-level format & check, it say that all the various checks that it makes are ok .
  • Maxtor Master
  • 27,725 Answers
You could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps dont forget to vote
Posted on Mar 11, 2011
Seagate shows there is atleast 30 GB/300GB being used but cannot be seen when clicked.
enable hiden files and folder and system files if it is a external hard disk
or
1 go to command prompt
2 type the drive letter example X:
3 you get X :\>
4 type the command attrib -R -A -S -H /S /D
5 WAIT UNTIL YOU GET X:\>
6 IT WILL SHOW ALL YOUR FILES INCLUDE SYSTEM FILES
Sep 16, 2013 | Seagate FreeAgent Computers & Internet
I cannot copy files greater thn 4 GB into my new transcend 500GB hard, it shows error, tht not enough disk space in the external disk drive, even whn more than 300GB is free in the hard disk..
Hi 711jay
Open the Computer folder ( My computer ) , right - click on the drive , select properties and quota . Look if the quota management isn't activated .
Best regards ,
fanaudi .
May 25, 2011 | Office Equipment & Supplies
I've a Samsung G2 Portable HX-MU050DC/GW 500GB. - I was using it fine on PC1 when a Scan Disk Message Window (bad sector) popped out. I did a scan disk, nothing happened and continue copying and pasting...
when you see "bad sector" you need to not only run scandisk, you need to tell it to "automatically repair bad sectors" if you didn't do this, then you have written to the bad sectors and that data can not be retrieved. As for the MAC issue, you didin't say what format your HDD was, if it was FAT32 it should mount on MAC, but not if it is NTSC as MAC can't read it. If I were you I would copy all the files from your HDD to a wiindows machine and then run scandisk again, only this time make sure to auto repair, these sectors will now be gone, and its not a great loss and does happen quite ofter unfortunately. The data you have written to the bad sectors "CAN NOT" be recovered, you might get part of it, but most likely not. Good Luck
Mar 24, 2011 | Samsung G2 Portable External HX-MU050DC/...
My WD 1TB hard disk drive shows me loaded with 300GB capacity of folders but when they are not seen on my pc
1) Open any folder on your your computer and go to: Tools > Folder options > View tab > check "Show hidden files and folders" and uncheck "Hide protected operating system files". 2) Look at your hard disk again, if you still can't see any files on it, there must be an error of your disk. To solve it, go to: My Computer (or Win+E keyboard shortcut) > Right click on the drive representing the 1TB hard disk > Properties > Tools > Check Now... > Check both boxes to fix errors.
Mar 07, 2011 | Western Digital My Book Essential Edition...
300 gb hard drive but only 32 gb is visible
Check your jumper settings on the drive it sounds like youve got the jumper over the 32gig limit pins.....cheers from Scott and plz vote
Oct 23, 2010 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Can not remove folder from HD
Try checking the hard drive with check disk (Run the command chkdsk /f, from the run command). This is mostly due to some cross-linked files and folders on the hard drive.
This may also happen due to some virus, so update your antivirus and run a complete disk check.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | HP Computers & Internet
Xp did not give drive a letter
Go into Disk Management...Look for your drive and either it has not been formatted and assigned or just not assigned you can right click on the disk and assign to a drive letter.
Feb 17, 2010 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Hard drive connects and then disconnects quickly
Sounds like a bad solder joint or break on the circuit board. If the data on it is important, you may need to use a data retrieval service.
Jan 18, 2009 | Maxtor DiamondMax 10 6L300R0 (6L300R020PK)...
Maxtor DiamondMax 10 6L300R0 (6L300R020PK) 300 GB Hard Drive Logo
102 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
