Question about Craftsman Air Tools & Compressors
I have an older model Sears Craftsman air compressor, 1 hp, 100 psi, twin cylinder. Model 106.154541. The compressor comes on fine, but when the pressure gets to 40 psi or so the belt starts to squeal, then the squealing gets louder until it is constant, and becomes intolerable long before hitting 100 psi. Then the pump wheel stops. What's going on here?
    Sergeant:
    Champion:
  • 232 Answers
Could be the bearing in the pully wheel rides on,,not the belt,,,While its running spray some belt dressing on belt to see if its the belt,,,while running get a can of wd-40 with long nosel attachment and spray the armeture that tures pully when you spray it if its the bearing it will stop makeing noise momentarly, than come back again than as you spray it it will stop as long as you spray. BE CAREFUL. Bearings wear out when old,,,like us!
Posted on Mar 11, 2011
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
I have an older Sears Craftsman air compressor 1hp, 100 psi twin cyl Model 106.154541. on the cyl base there is an oil fill directly across from this on the opposite side of the cyl base there is another...
The pump used on your compressor was incorporated into different designs thus needed access to oil fill from one side or the other. Part number for oil plug was std-220 or 27642, but you can use just regular standard pipe thread plug with square head. If the oil plug fits the other hole. Buy plumbing parts at Lowes. Good Luck
Mar 25, 2011 | Craftsman Air Tools & Compressors
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
Low air pressure
This sounds like it is either the pump is leaking from the piston or more commonly, the rubber seal that seals the outlet tube to the cylinder head blew out like mine. Let me guess, it got a lot louder than it was originally? The seals are readily available from sears parts direct, its like 3 bucks but shipping is around $8. Hope this helped
May 23, 2010 | Craftsman Air Tools & Compressors
I have a Sears 3 H.P. electric 30 gal air compressor
This link will take you to sears web site, where parts are available. I have linked you to the parts list. If this does not take you there, go to www.sears.com and click on the parts direct tab and enter your model number.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=106.154880&productCategoryId=0703000&brandId=0247&modelName=CRAFTSMAN-TWIN-CYLINDER-TANK-TYPE-PAINT-SPRAYER&diagramPageId=00001&documentId=00001361&pop=flush
Oct 30, 2009 | Air Tools & Compressors
I have a craftsman 6.5 60 gal horz compressor.
i have the same piece of junk, iv rebuilt it 3 times in the past 5 years always a piston rod snapped and then it was running on only one. they are built like ****. anyhow I finely got smart and bought a cast iron pump thats not only quieter but puts out twice the volume of air in half the time. it took some work but it was well worth it costing under 200.00. the rebuild kit from sears will cost over 100 and it wont last. the one from sears is a direct drive pump and you will be told no one makes a direct bolt on but all it takes is cutting the aluminum housing away from the motor and welding a pin or bolt to the end of the shaft and putting a pully on it, you will also have to turn the motor to the side but let me tell you this was the best move i ever made. you can pick I bought my new pump from a place called heavy dudy air in ga. 877-447-2485
Oct 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Oct 05, 2009 | Air Tools & Compressors
Craftsman air compressor 1 HP 12 gal 125 psi
this is probably an "oilless" compressor, it has "piston" with a thin ring of leatherlike material acting as a piston ring, the "cylinder" is an aluminum sleeve - what usually happens is the cylinder gets scratched from dirt or just wear or the leather ring deteriorates, that's why it will go only so far - the only fix for this is to replace the cylinder and the piston
Aug 18, 2009 | Craftsman Air Tools & Compressors
My Sears 1 HP compressor motor starts to slow down to almost zero RPM as pressure approaches 60 psi. Up until recently it produced 100 psi. Compressor rotates freely at shut down (no binding, etc). Is this...
IF IT HAS BELTS THE BELTS COULD HAVE BEEN LOOSE AND SLIPPING.. MOTOR COULD BE GETTING HOT DUE TO TOO SMALL OF CORD OR SMALL GAUGE DROPCORD. INTANK CHECK VALVE COULD BE GETTING CLOGGED NOT ALLOWING AIR TO PASS THRU IT. UNHOOK DISCHARGE LINE FROM HEAD TO THE TANK, THIS WILL ALLOW PUMP TO RUN UNDER NO STRESS AND SEE WHAT HAPPENS.
Apr 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
484 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
