Question about Liebherr Refrigerators
We have a liebherr 7082 214 model. We cannot set the temparature for the freezer. after a few seconds the temperature digits disappear and two flashing lights appear
The two flahing lights are normal if the freezer is warm. It will display temperature when it gets cold. If it doesn't get cold there is another problem.
Posted on Aug 09, 2008
How do I change thermostat?
Look inside the cabinet for a black dial with numbers 1 to 9. Usually top left or right and at the rear. If it is a digital display, look for a 'set' button and arrows.
Should have looked first!
  • Electronic control system:
  • MagicEye with LED digital refrigerator temperature displays
  • SuperCool function
  • It states you can get instruction manuals from the site, but you have to find a 9 digit service number.
    You've misplaced your operating instructions? No problem.
    It's simple and convenient to download the latest operating instructions for your LIEBHERR refrigerator and freezer as a PDF document here.
    Just enter the 9-digit service number of your appliance, which you'll find on the rating plate. The rating plate is situated on the inside left of upright appliances and on the outside right of chest freezers. (Drawing )
    http://www.liebherr.com/HG/en-GB/region-UK/94270.wfw
    Pictures of where to find the code
    http://www.liebherr.com/CMS/images/Typenschild.jpg
    It says you can get instruction manual
    Oct 04, 2015 | Liebherr K3660-20 Refrigerator
    The temp says 14 and 8 but should be -21 and 3? Can anyone help
    Controlling the Freezer temperature
    The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
    freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
    temperature in two star sections are slightly higher than other freezer compartment.
    Controlling the Fridge temperature
    The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
    temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
    begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
    If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
    The refrigerator does not work at all or it does not chill sufficiently.
    • Check that the power plug is properly connected.
    • Is the temperature control on the display panel set to the correct
    temperature? Try setting it to a lower temperature.
    • Is the refrigerator in direct sunlight or located too near a heat source?
    • Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
    Dado
    Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
    I have a Liebherr CUPsl 3221 freestanding fridge/freezer. Does any one know what are the approximate temperatures in the freezer area at different settings? (1-7, manual button in the refrigerator are
    Their are no direct connections between the number and the temperatures on refrigerators and freezers. Is is based on surrounding temperature, in the room. That is the reason they used numbers and do not mark teperatures.
    May 23, 2014 | Liebherr Refrigerators
    The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
    I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
    Oct 18, 2012 | Liebherr Refrigerators
    Liebherr KD 900 fridge freezer bought 2001. Both the freezer and fridge are losing temperature, as though it is defrosting and then clicks back on and seems to regulate itself again. This has happened...
    The defrost timer sticks in defrost mode and then comes out of it. I've been out of the service industry long enough to not be able to tell you on your model where it is located. Defrost timers on frost free refrigerators are a very common problem.
    Oct 11, 2017 | Liebherr KES3660 Stainless Steel...
    How should I set the temperature. The refridgerator and freezer is not able to maintain a consistent temperature. What is the correct freezer and top refridgerator setting and how do I know it has accepted...
    Basically the thermostat controlls the freezer temperature which turns the compressor on and off.
    The refrigerator section receives cold air from the freezer to cool it down.
    So when the freezer is off there may not be enough cold air left for the refrigerator.
    Fridges can never give you a perfect temperature every time there will always be a drift one way or another.
    Once you reset the temperature the numbers or an led should blink at you to confirm the changes you made
    Mar 25, 2011 | Liebherr KGK 2833 Comfort Bottom Freezer...
    Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
    If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
    Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
    Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
    Please take a moment to rate my reply.
    Sep 22, 2010 | Microwave Ovens
    Freezer cold but not freezing
    Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
    Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
    Thermometer
    YOu have to be more clear on the post it dont make much since, also if its brand new should be under warranty
    Aug 21, 2007 | Liebherr KGBN 3846 Premium BioFresh Bottom...
    Refrigerators Logo
    1,168 people viewed this question
    Top Liebherr Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Shehu Pro
    Shehu Pro
    Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
