Question about Konica Minolta DiALTA Di200 Copier
I current have a konica 7920 which i just moved to my new office. The machine work fine until It was moved. I reassembled the system and started it back up. the finishere tray appeared to stuck and was making noise and then i recieved an error message COBAO on the printer. I attempted to turn the machine off and back on with no success. I also attempted to disconnect the finshere from the main unit, but still received the same error. I also turn the machine off and disconnected the main power with still the same results. I don't know if this system can be reset, fun without the finisher or what. Can some please advise me on resting the system or some alternative repair/solutions!
    Scholar:
  • 177 Answers
Hi one thing you can try is turn oiff the machine hold down the utility key switch turn back on the machine keeping the utility button pressed down after 20 seconds release the utility key on the display it will come come up with trouble reset on the screen touch this on the screen and the machine will reset the error code leave the finisher detached from the machine
in regards to the finisher you will need a certified engineer to look at this temp you can put a box between the finisher and the machine to catch the paper
Posted on Mar 13, 2011
  • tzordan Mar 14, 2011
    I attempted your suggestion, but can up with the same error message CABAO. This is a Konica 7920 Machine. What other resets can I try with the finisher know disconnected?
  • walter jansz
    walter jansz Mar 14, 2011
    if you ope the front doors on the left or right side there is a grey cover looks like a small square shape held in with one screw remove the screw behind the cover is a board with a trouble reset button only push the trouble reset button in there may be more than two buttons the buttons are small black and it shold say trouble rest
    MAKE SURE YOU HAVE THE FINISHER OFF THE MACHINE UNPLUG THE MACHINE FROM THE POWER OUTLET WAIT FOR ABOUT 2 MINUTES THEN PLUG THE POWER BACK INTO THE WALL OUTLET AND SEE IF THAT TAKES YOUR COFE AWAY IT SHOULD DO
    Please get back to me if none of the above works
Konica 7920
Sir/ Mam,
The image unit could be bad. take alcohol and clean all metal contacts on the outside. Then reseat. GET a second one.
May 21, 2014 | Konica Minolta Imaging Unit 950-472...
Konica Bizhub 200 touch screen doesn't get past the Konica logo screen.
power off the machine and take toner bottle out. Then turn the machine without the toner bottle. let it run it should ask for the toner bottle to be replaced. Please wait is the machine is conducting house chores prior to READY TO COPY. one is to ensure toner in the developer unit is properly mixed. Also might check. Power on the machine while depressing the utiltiy/counter button hold down until you see trouble reset touch ok power off then wait 10 seconds and power on. if neither works get a tech out to look at iti
Mar 30, 2017 | Konica Minolta bizhub 200 Printer
Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
Nov 28, 2012 | Konica Minolta bizhub C450 Touch Panel...
KONICA MINOLTA PagePro 5650 error code of 0300 Polygon MOT
Polygon motor is inside the print head where the machine LASER is located the motor spins around 35,000 RPM. Moving the LASER beam across the drum with image. Sound like you need a new print head. Try the below web sit for a start.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 09, 2012 | Konica Minolta PagePro 4650EN - Printer -...
Konica minolta biz hub 250, causes all applications to not respond for about 1 minute every time we print from a machine with windows 7 64 bit pro. Got the latest window 7 64 bit driver, printer works...
Might have a KMBS tech come out and update the copiers Operating system (Firmware). Driver is for the computer firmware is for the copier which is located on a secure server KMBS wishes to protect its printing software
Apr 29, 2017 | Konica Minolta bizhub 250 All-In-One Laser...
The machine has been idle for two years due to office closure. I started it today and everything works fine except the touchpad which looks fine and switches from copy to scan to fax. Is there a way/need...
To default the priority display screen, perform the following:
1. Press Utility button.
2. Select Administrator Settings and enter passcode (default 12345678).
3. Select System Setting.
4. Reset Settings.
5. Select System Auto Reset.
Dec 18, 2010 | Konica Minolta bizhub C250 All-In-One...
HL-2170w won't print with Windows 7
Windows 7 will not work with earlier Windows versions of printers
Feb 28, 2017 | Brother HL-2170W Laser Printer
I have a Konica 7033 copier with error code F-35-2
Access the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
2. Press [1: Software SW].
3. Select software dipswitch 3-1 using the arrow keys.
4. Set the switch to OFF (0).
5. Press [Return] to end the setting.
6. Power the machine OFF/ON to exit the 25 mode.
good luck
May 04, 2009 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
251 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
