Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Why does the tv have component video when its an analog tv and how do you hook it up
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
Component video IS analog. It is also known as Y-Pr-Br. These connections are typically RCA connectors colored Red/Green/Blue.
Component will give you the highest quality signal for analog connections (vs Composite Video (yellowRCA) or S-Video(the round 4 pin connector) Of course HDMI will be best if it is supported.
Keep in mind video signal formats are NOT interchangable, you cannot plug a Composite Video into a Component Input
All you need is a component source (typically a DVD player) and 3 RCA cables and match the colors up.
You will also need to connect the Audio connectors (Red/White) with RCA cables, as the Component is Video only
I hope this helps,
Magoo
Posted on Mar 11, 2011
WELL???? PDP4210EA hooking up to it?
I was able to find a service manual online which lists the inputs for that TV as the following:
  • RF connector (cable/antenna)
  • Composite (yellow video, red/white audio)
  • S-Video
  • Component (red/green/blue video, red/white audio)
  • D-Sub (analog PC connector)
  • DVI (digital PC connector)
Your Playstation would need to be plugged into either the component or composite connectors depending on which Playstation you have. The Playstation 1, Playstation 2, and Playstation 3 all can use the same composite cable, and the Playstation 2 and Playstation 3 can both use the same component cable. The Playstation 4 only uses HDMI, which your TV doesn't support, so you would need to use an HDMI to component converter (under $20 on Amazon).
As for the Roku, same rules apply, but it again depends on your Roku model.
Oct 24, 2017 | iLO Televison & Video
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
I am using a logitech harmony one remote. i have a yamaha rx-v463 hooked up to a phillips hdtv, i am running hdmi from revr to tv. i have cable box hooked upi hdmi to recvr and bluray player hooked up to...
The remote has nothing to do with this.
Get into the manual. Page 14 says Component Video In will go to Component Video Out, not HDMI. No analog-digital video conversion is implied.
Jul 08, 2011 | Yamaha RX-V463 Receiver
Could I hook up Apple TV with this tv?
Read the Apple Tv box owner manual can it be hook up wih RCA component R,Y,W cables,than yes.This tv is an analog tv only can be functions buy component cables not anything else will able to hook up with analog tv to get a video picture.
Dec 19, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
My digital tv tuner converter box with analog Zenith converter bo
Most DTV converter boxes have 2 outputs available; RF and component video. The RF goes in between the antenna and the TV and acts as a frontend tuner. The TV needs to be set to Channel 3 or 4 (depending on the box) and left there. All tuning is then by the converter box. By the way, you need to scan for channels as part of the setup. The other method is by using the audio/video component inputs to the TV and the set would then select AUX 1 or 2 etc to get the box input, and tune via the box.
Oct 03, 2009 | Zenith Analog to Digital Audio Converter
I have a HP a705w desktop and I am trying to hook to a TV
You don't say which graphics card (many people change the stock card)
Your best bet is if your card has S-VIDEO out.
Only use a good quality cable as many of the s-video cables are just not up to the job.
There are also VGA to COMPONENT cables about. Experience shows that this does not work as well as should be expected as it too has a pretty high chance of failure to analog tv.
There is a 50/50 chance of it not working with analog. That figure changes dramatically with flat panel tv
Aug 24, 2009 | HP Computers & Internet
Hdmi in but no analog out
the guy was wrong. the analog and digital portions of the receiver are totally separate.
according to Yamaha:
"Be sure to connect your video components in the same way you connect your video monitor to this unit. For example, if you connect your video monitor to this unit using an HDMI or COMPONENT VIDEO connection, connect your video components to this unit using
the HDMI or COMPONENT VIDEO connection."
sorry bud:-(
Feb 28, 2009 | Yamaha HTR-6130 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Help!!
Do you have your other components wired to the Onkyo. The monitor output isn't the best way to go. If your TV has component inputs or an HDMI you should run one of those instead, running a composite video cable will only get you analog at best.
If you are content with running analog you may need to go into the menu on your tv and select the type of video input you are using. The same goes for your receiver, switch the output to analog out.
Jul 17, 2008 | Onkyo Audio Players & Recorders
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
