Question about Jenn-Air Kitchen Ranges
Digital clock begins blinking 00:00 and a tone sounds. Then it returns to normal. However, oven will not work. Does this intermittently.
  • baileygl Jul 31, 2008
    Proposed solution did not address the non-operation of the oven.
  • 426 Answers
How often does it do this? it sounds like the "cook" timer is actavating this could be someone in your house messing with you, or there is a problem with the board, try resetting the oven by turning the breaker off for 5 or 10 mins
Posted on Jul 31, 2008
  • Lee N.
    Lee N. Jul 31, 2008
    sorry i didnt see the intermittent problem, you might want to check the connections to the control board as well
  • Jenn-Air Master
  • 19,396 Answers
The clock control board is faulty. You find replacement here.
Insert your model number to find parts.
How do I set day and date? All else is set
SETTING THE TIME
Note:
When the signal is being received (as indicated by the atomic indicator signal)
you will not be able to make any setting or adjustments to the clock.
1. To begin setting the clock, press and hold the MODE button located on the back
of the clock for 3 seconds to enter the TIME setting mode.
2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button
to set the HOUR in one hour increments. Press the UP or DOWN button as
necessary until the correct hour is displayed.
Note:
If you are in the 12 hour time format, be sure you are in the correct AM or PM
time period. When the "PM" indicator appears on the display, the time displayed is in
the 12 hour period between 12:00 noon and midnight.
3. Press the MODE button again to exit the HOUR setting and enter the MINUTE
setting mode.
4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN
button to set the MINUTES in one minute increments. Press the UP or DOWN
button as necessary until the correct minute is displayed.
5. Press the MODE button again to exit the MINUTE setting and enter the
SECONDS setting mode.
6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN
button to reset the SECONDS to zero.
7. Press the MODE button again to exit the time setting mode. The clock will
automatically return to the normal time display mode.
Note:
If no settings are made within 30 seconds, the clock will automatically return
to the normal time display mode. If this happens, you will need to start the time
setting procedure again from step
SETTING THE CALENDAR
1. Press the MODE button (located on the back of the clock) twice (do not hold the
mode button) to display the CALENDAR.
Note:
The YEAR icon will be shown on the display indicating you are in the year
display mode.
2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting
mode.
3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button
to set the YEAR in one year increments. Press the UP or DOWN button as
necessary until the correct year is displayed.
4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting
mode.
5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button
to set the MONTH in one month increments. Press the UP or DOWN button as
necessary until the correct month is displayed
6. Press the MODE button again to exit the MONTH setting and enter the DATE
setting mode.
7. The DATE digits on the display will begin to flash. Intermittently pressing and
releasing the UP or DOWN button to set the DATE in day one increments. Press
the UP or DOWN button as necessary until the correct date is displayed.
Note:
The day of the week will automatically set according to the month, date, and
year.
8. Press the MODE button again to exit the calendar setting mode. The clock will
Note:
If no settings are made within 30 seconds, the clock will automatically return to
the normal time display mode. If this happens, you will need to start the calendar
setting procedure again from step 1
Dec 09, 2014 | Westclox 70026A LCD Atomic Digital Alarm...
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
How do you set the clock on a cde-9870
Hello there,
This is from Page 7 of the Owners Manual, found through Alpine's site.
1 Press and hold MUTE/SETUP for at least 2 seconds
to activate the SETUP mode.
2 Press or to select the CLOCK ADJ mode, and
then press //ENT.
The time indication will blink.
3 Press or to adjust the hours while the time
indication is blinking.
4 When the hour has been adjusted, press //ENT.
5 Press or to adjust the minutes while the time
6 Press and hold MUTE/SETUP for at least 2 seconds
to return to normal mode.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold //ENT for at least 2 seconds
after setting the “hour.” Minutes will reset to “00”. If the display
shows over “30” minutes when you do this, the time will advance one
hour.
• Pressing AUDIO/RTN will return to the previous mode.
• If no operation is performed for 60 seconds, the unit will return to
normal mode automatically.
Jul 12, 2010 | Alpine CDE9870 CD Player
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Need set up instructions for the KATEC #38 travel alarm clock
I bought one of these for $3.00. I found it in the clearance sale aisle at my local Wal-Mart. The instructions refer to it as being an "Automobile Clock."
In the instructions, "M" refers to the "Mode" button, "S" refers to the "Set" button, and "D" refers to the "Date" button. These are the instructions that came my KATEC #38 travel alarm clock:
1. In normal mode, there will show hour, minute, second and week. Push "D" to show date and push "S" to show alarm-time.
2. Adjust alarm-time: Push "M" two times to enter into alarm mode. Push "S" to choose hour and minute. Push "D" to adjust the right time. Finally, push "M" to return.
3. Adjust real time: Push "M" three times to enter into adjust time mode. Push "S" to choose second, minute, hour, day, week, and month in order. Push "D" to adjust correspondence number for right volume. Finally, push "M" to return to norm-al mode.
4. Sport Function: Push "M" for one time into sport watch function mode. The beginning state is show as 0:00:00. Push "D" to enter into recording time. Push "D" again to stop. Push "S" to return to the beginning mode 0:00:00.
5. Adjust ON/OFF alarm mode. In normal state, push "S" and "D". You can choose alarm on or off. When alarm operates, the alarm symbol will be displayed on.
Jan 09, 2010 | GE 74801 Clock Radio
How do you reset the clock on a 2007 Honda Accord?
Press and hold the SOUND button until you hear a beep. The displayed time begins to blink.
Press on the H (Preset 4) side of the bar until the numbers advance to the desired time.
Change the minutes by pressing the M (Preset 5) side of the bar until the numbers advance to the desired time.
When you are finished, press the SOUND button again to set the time.
You can quickly set the time to the nearest hour. Pressing and holding the SOUND button, then pressing the R (Preset 6) side of the bar sets the clock back to the previous hour.
If the displayed time is after the half hour, the clock sets the clock forward to the beginning of the next hour.
For example:
1:06 would RESET to 1:00.
1:52 would RESET to 2:00.
Hope this gets you there.
Dec 21, 2009 | 2007 Honda Accord Sedan
Oven display blinks between 0:00 and auto. nothing happens when pressing buttons and oven is in auto-mode and cannot be used.
Power had gone out. And the oven don't work when the clock is not set. So I ajusted the clock and bingo! everything in order!
Aug 31, 2009 | Zanussi Ovens
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Clock
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
function.
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
Kitchen Ranges Logo
95 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal De GO PATS
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
