Question about Panasonic TH-42PX60U Television
TH50PZ700U 50" panansonic plasma tv
  • dgleaper Mar 13, 2011
    thank you for answering and thanks for the manual been trying to get that info from somewhere thanks again
  • Panasonic Master
  • 19,396 Answers
Hi.
The error does not point at sustain board, but at DG board.
Thirteen blinks means communication error with IC8001 which is the video signal processor in the DG board. The DG board is tested verifying that voltage at the IC pins corresponds to value in service manual.
The service manual reporting blink codes and indicating how to access and test DG board has been uploaded here: panasonic_th-50pe700u_th-50pz700u_ch_gp10dhu_[ET].pdf.
Regards.
Ginko.
Posted on Mar 13, 2011
  • Ginko
    Ginko Mar 13, 2011
    Hi.
    You are welcome.
    All the best.
    Ginko.
When I turn on my 50" Plasma TV the light goes from red to green. The Green LED flashes 14 times then solid. There is a white raster but no picture or sound.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 16, 2015 | Zenith Z50P3 50 in. Plasma TV
Constant flashing red light near main on/off switch
A constant flashing light near the main power switch normally indicates a problem with your device's electronics, ranging from image board errors to power supply failures.
It is best to contact the manufacturer's customer support line to get the appropriate trouble codes and best advice.
Hope this helps.
Nov 05, 2013 | Panasonic TH50PZ80BCAB 50 in. HD-Ready...
Will not turn on red light flashing
How many times is the power light flashing? This generally is an error code from panasonic. In the tech world they call this the red light of death - panasonic plasmas had multiple issues - tell me how many flashing lights and we can go from there. when you plug it in - push power and count how many times it flashes before the pause and then it will do the same thing again and again.
Thanks,
Michael
Feb 06, 2011 | Panasonic TCP50C2 50 in. TV
Help my 42 inch panansonic plasma tv will not turn on red light just blinks
Hi:
Replace or have the power supply serviced, the most common failure with panasonic plasmas is tthe power supply.
Dec 23, 2010 | Panasonic TH-42PZ700U 42 in. Plasma...
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Plasma TV Does Not Turn On - continous Red Flashing Light
Had a similar problem with my Sony. Unplug for 36 hours and try again.
Aug 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
Tv wont turn on
The green light flashing indicates an error code, plasma tv's cannot be repaired at home without the right equipment and service manual, the fault could be power supply, processor or virtually anything, what technicians look for is the frequency of the blinking and the time between sets of blinks, this normally gives the tech a code that enables them to go to the right area, the only thing anyone can tell you is that the processor is probably ok, you really need to get a quote or count the blinking and the timing eg: "blink blink short pause blink), and repost the fault, then we can possibly tell you where to look...Phil
May 18, 2009 | Akai PDP4206EM Television
Panasonic TH-42PX60U Television Logo
251 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
