Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
The machine will not steam or heat - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Mar 23, 2011
Steam mop won,t steam. Have tried all suggestions in user guide. Water won,t heat up. Machine becomes warm. Water ' vinegar will slowly drip out of base - so not blocked. Help,,
It could still be blocked, not totally blocked but enough to keep the steam from coming out as strong as it should.
Mar 14, 2017 | Vacuums
It heats water inside the machine, but won't steam
contact Shark . they will know better and faster than we could find it .
Oct 20, 2015 | Shark S3501 Steam Pocket Floor Mop With 5...
I have a vax steam mop it was working perfectly
possibly not heating if you have water and no heat it could be a problem with the heating cycle that allows the steam to work .
You need a technician to have a closer look at it. It could be something small like a wire off or it could be major like an element problem. Take it in & ask for a quote on getting your machine working again.
Sep 01, 2014 | Vacuums
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
Jan 26, 2014 | Oreck VersaVac Bagless Vacuum / Steam Mop
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
Machine will not produce steam. Machine will heat up but not enough to produce steam. Help ...
heatman101
;a
Jul 31, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: shark steam mop has water, but there is no steam....
I tried running vinegar through as you would a coffee pot to get rid of hard water scales. This did not work. Then I noticed that the light behind the shark decal on the front of the machine was going off and on. And sure enough as I moved the cord around the light would come off and on. Looking closer I could see the the heat had melted thru some of the cord.I bought mine at Target before xmas last year, throwing away the sales slip after several months so I guess there is nothing I can do about it.
May 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stoped heating the water, in my Ultra steam shark 2.
there is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
Jul 29, 2009 | Kenmore Euro-Pro Ultra Steam Shark II Hard...
No Steam after heating up
Sounds like the switch on the handle or the steam release solenoid on the steam chamber is faulty ,use a volt meter/tester to see if you have current to the solenoid when you turn on the switch.
Dec 02, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
21 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
