I need a driver for my polyview moitor model v396
  • 496 Answers
There are no drivers for monitors. Your system might be inflicted with an other problem other than a missing driver.
Good Luck!
Posted on Mar 11, 2011
KINDLY GUIDE ME TO DOWNLOAD Polyview V372 DRIVER
Here is the link to a site to download the driver you request. http://www.drivermedic.com/?t=Polyview%20V372%20Driver
Aug 27, 2011 | Home
Trying to find a video device driver for an Amptron Polyview V293
try this link below to download the driver
http://www.driverstart.com/start592730.html
Aug 10, 2010 | Amptron POLYVIEW 19" Monitor
BLACK SCREEN
Does it go black if you you use it as just one single monitor? If it does, you will need to open up to inspect the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 20, 2010 | Chi Mei Corporation Polyview V396 (Black,...
Polyview v396 won't turn on
raphy916, You should view the longer video clips dealing with LCD monitor (display) disassembly and or repair of LCD switch-mode-power-supply repair and INVERTER repair. then you will know if you should attempt to effect a repair to your LCD. Here is a little hint for you. Take pictures or video of your work progress so you can reassemble unit without EXTRA parts laying around or connectors replaced where they shouldn't be. What should you visualy inspect for??? Look for "frosty" looking solder joints on the bottom of the SMPS/inverter board, and swollen "tops" on electrolytic filter capacitors. Youtube is good for pictures and video of "bad" and or "failed filter caps" !!! Note! You didn't mention if the powersupply (ac to dc) is "lay on floor black brick" or if your monitor plugs directly into the power strip. also how many "on" hours has this unit seen over it's life???? Let me know if this info was at least a bit helpful to you. I'm louie12fix on fixya or lmistyrel@aol.com
Oct 01, 2009 | Chi Mei Corporation Polyview V396 (Black,...
I need an owners manual for a Yamaha AM/FM Tuner receiver, Model #RX-V396 Can you help?????????
You can download instruction manual for RX-V396 from Yamaha Customer Support website, just register with your email address and download manual.
Jan 26, 2009 | Audio Players & Recorders
I have problems with my LCD polyview
These monitors are plug and play compliant and should not require any drivers. If you are having video problems it may be the video card.
Apr 06, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Polyview v396
Check the signal, is the monitor digital or analog, if your video card has a DVI conenctor, then the monitor should be DVI, so it needs to be set to Digital, If your monitor came with a CD, check to see if it has drivers that need to be installed
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Polyview V17E
Same as before this sounds very similar to the problem that I had with my polyview v396 19" . Its a power supply problem unclip the panel withdraw the power supply it plugs in on its own seperate board. Look for capacitors that bulge and replace them in fact replace them all on tha board not that hard. Replace them with the same rating voltage and micro fards. Cheaper than relacing the whole panel, hope this helps. :)
Dec 06, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
