Question about Grundig GF70-600 TV
My Venus TV set has a child lock display what can i do? it is a second hand product of which i don't have the remote.
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
How to open child lock on cineplus LG TV manually as remote is not working
Try entering code 0000 or 1234 for the child lock.
Otherwise try holding down the DISPLAY key on the remote or on the front of the tv for 10 seconds to disengage the child lock.
Jan 28, 2011 | LG 42LC2D 42 in. LCD HDTV
Hii i need to unlock the child lock on my LG tv and my remote is also not working at all..My Tv shows only one channel and i can't explore it further...please help
Otherwise unplug the power cord and leave it out for a few hours to clear the internal memory and reset to original settings.
Good luck and please post back if this helps.
Jan 25, 2011 | Televison & Video
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
Sony DAV DZ230 Child Lock
hello You can deactivate the buttons on the unit
(except for "/1) for preventing misoperation,
such as child mischief (child lock function).
When the child lock function is activated, the
buttons on the unit are locked and “ ” lights
up in the front panel display. (You can operate
the system by using the remote.)
Note
•When you operate the buttons on the unit while the
child lock function is on, “CHILD LOCK” appears in
1 Press SYSTEM MENU.
2 Press
X/x repeatedly until “CHILD
LOCK” appears in the front panel
display, then press or
c.
3 Press
X/x to select a setting.
The default setting is underlined.
• “OFF”: Child lock function off.
• “ON”: Child lock function on.
4 Press .
The setting is made.
5 Press SYSTEM MENU.
The system menu turns off.
Tip
• You can activate the child lock function by pressing
x for more than 5 seconds (“ ” lights up in the
front panel display).
To cancel, press x for more than 5 seconds so that
“ ” disappears from the front panel display.
Deactivating the Buttons
on the Unit good luck
shaun
Sep 12, 2009 | Audio Players & Recorders
My TCL 2027U's child lock in on and I can't unlock it
kapag naCHILD LOCKED tapos hindi na maopen ang TV,,,pero nakastandby sya...sira na din ang remote....
anu pwedeng gawin???
please answer...
THANKS
Nov 28, 2008 | Akira EPM-420A 42 in. Plasma Television
Chuld unlock
to unlock the parental control on a Telefunken TV that has a blue screen and a red padlock on the top left hand side, hold down the display button on the remote for 10 seconds and it works
Sep 02, 2008 | Televison & Video
Child lock will not allow my tv to turn on
i was programming my television by hand because i do not have a remote to my television and i accidentally set the child lock and now my tv will not turn on what can i do to fix my tvtv is on standby, standby light is on. can turn tv on with programable remote after pressing on button several times to set code on remote. press any function button and screen says child lock is on. can't get anywhere pressing any buttons, turn tv off with on/off button and tv goes back to stand by. don't have magnavox remote any ideas?
Jul 19, 2008 | Philips Magnavox 20MS3442 20" TV
Child lock on Telefunken TV
try pressing display button on remote for 5 seconds
Dec 11, 2007 | Televison & Video
hold the display button down for 3 seconds
Aug 02, 2007 | Compaq iPAQ H3830
Televison & Video Logo
60 people viewed this question
Top Grundig Televison & Video Experts
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
