Question about Gestetner DSc232 Copier
AFTER THE SERVICE MODE SCREEN APPEARS WHAT DO I DO?
  • santosj27
    santosj27 Mar 11, 2011
    What do you whant to do??
    It is because any error code (SC)??
    You have to give more info so i can help you
  • 34 Answers
I guess it depends on what you are trying to accomplish. What exactly are you wanting to do in the service modes? If you are resetting a service error, then you need touch the "copy SP" on the touch screen. At the the top of the screen you will see a button that say "SP direct", touch that button. With it highlighted, enter the numbers 5810 then press # key. Then the number "1" should reset the code. If it's not the number "1" then it will be an "execute" button. After that, switch the machine off then back on. The code should be reset, unless the problem is not fixed. Then it will come back.
If that is, in fact, what you are wanting to do.
Posted on Mar 12, 2011
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
Tip
ERVICE MODE AND POWER SUPPLY CIRCUIT
SERVICE MODE AND POWER SUPPLY CIRCUIT
Purpose: To bring the color adjustment of each component into standard alignment.
Symptom of Misadjustment: If this adjustment is incorrect, component signals do not reproduce the corresponding color.
1. Input 1080i 100% Color Bar signal.
2. Enter the service mode.
3. To enter the Auto Calibration adjustment mode, press [6] button on service the remote control unit.
4. To start auto adjustment, press [1] button on the service remote control unit.
- In the auto adjustment mode, "Please wait" appears on the screen.
- Upon completion, "OK" appears on the screen.
TO KNOW MORE CHECK THE LINK BELLOW
on Feb 18, 2015 | Emerson Used Original LC195EM82 Remote...
How can I enter service mode on a Konica C7000? It is in fault mode with a code of C3501
This reset procedures reset the copier fuser the hot part if the code comes back aftyer procedure DO NOT DO AGAIN IT CAN CATCH ON FIRE RUINING A PERFECTLY GOOD DAY!!!!!!!!!!! Get a tech out to look at it
1. Be sure that the ordinary operation screen *1 is displayed.
Press [Utility/Counter] button.
2. "Utility screen"
On the Operation panel, press the following buttons.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
When the CE password has been set, entering the password is required to enter the service mode.
3. "Service Mode Menu screen"
The service mode appears.
*1 Default is [MACHINE] screen.
go to
03 System Setting
• 01 Software DIPSW Setting
set the DIPSW 3-1 to 0.
why you do it once then get a tech out to look at it. DIPSW3-1 is set to 0 before defective parts are fixed, it may cause fire
Jan 04, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub Pro C 6000 L. What does error Code C 3505 indicate?
Fusing high temperature abnormality The temperature sensor /1 (TH1) detects 150 °C or higher value continuously for a specified period of time.
Reset attempt once if the code comes back call a KMBS Tech
1. Be sure that the ordinary operation screen is displayed.
2. "Utility screen"
select 03 System Setting
Be sure to set the DIPSW3-1 to 0 after replacing the defective parts. If DIPSW3-1 is set to 0 before defective parts are fixed, it
may cause fire. DO NOT RESET MORE THEN ONCE COULD CATCH ON FIRE AT WILL RUIN A PERFECTLY GOOD DAY
To exit:
Service Mode menu screen"
Press [Exit] to back to "Utility screen".
2. The new settings become effective
Nov 20, 2015 | Konica Minolta Office Equipment & Supplies
Need the service code to enter service mode.
How to set up the service mode:
Service mode:
1. Turn the power on.
2. Press [MENU] button to display Setup menu.
3. Select "Features".
4. Select "Current Software Info".
5. Press [0], [6], [2], [5], [9], [6] and [Info] buttons on
the remote control unit in this order. The following
screen appears.
Code :
Pic code :
M I P S :
Press "POWER" key to exit.
Push 0key
Tuner :
S a f e t y :
safety_Non
Dec 11, 2013 | Canon NP 6035 Copier
Acer4310 suddenly appears white screen
Fyi, White screen for Aspire 4310 and 4520 after 2 years is normal. All you can do to fix it is CHANGE THE LCD.
Try to find any computer shop or go direct to Acer service center to change it
Mar 22, 2010 | Acer Aspire 4315-2963 Notebook
Error code f35 konica 7022
Turn on the main and sub power switches.
Keep pressing the
* button until the message
“Please enter service password.” appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press the key of the mode to be selected on the
screen. To return to the Mode Change Menu
Screen, keep pressing the
* button until the
screen appears.
When the adjustment ends, press
[1. Normal Mode] key and the basic screen will appear
Jul 14, 2008 | Office Equipment & Supplies
Panasonic Viera TX-37LZD70F - Red 'CHK' message on screen
Your set is in the service mode. TO EXIT THE SERVICE MODE PRESS VOLUME DOWN ON THE SET AND THE OK BUTTON ON THE REMOTE F0R 3 SECONDS.WHEN SELF CHECK SCREEN APPEARS UNPLUG THE UNIT.
Nov 19, 2007 | Televison & Video
76 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
 Larry
Larry
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
