Question about Delta 36 982 10 Inch Left Tilt 1 1/2 Horsepower Contractor Saw With 30 Inch Biesemeyer Fence, Table Board, And Legs, 115/230 Volt 1 Phase
My table saw will not start. the power source is good.
  • 17,129 Answers
If the motor is using a single phase supply there will be a capacitor which could have reduced in value- open.
If so try and use a capacitor in parallel to see if the motor works-- in this case the motor might hum and get heated up.
Posted on Mar 11, 2011
5 Suggested Answers
SOURCE: half way through cuttig a 2*4 my crAFTSMAN table
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Posted on Oct 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: Looking for a source for a 36-600 manual.
got it. go to Dewaltservicenet.com and in the middle of the page at the bottom under manual type in your number exactly as you have it and you can download the manual, it is 29 pages long if I have helped you with your request would you please rate this response accordingly and thank you.
Posted on Oct 30, 2009
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
  • 6 Answers
SOURCE: my mastercraft 10" table saw
Reset button on the motor?
Posted on Aug 27, 2011
Dewalt table saw stopped working
most like its damp, or the bushes need replaced, check the fuse in plug and also at source meter board for a triped fuse
Nov 12, 2012 | Dewalt Saws
I plugged in my table saw and everything worked just fine. I unplugged it, and then came back a few minutes later and turned on the table saw again. This time the motor was not running. Power was getting...
First of all, how did you determine that power was getting to the motor? If you can test for power with a voltmeter at the motor connections themselves and show power then the switch is OK and the circuit breaker is not tripped. Turn off power and attempt to turn the blade " CAREFULLY" and if it moves easily then the motor is probably defective and will have to be replaced. After turning the motor and finding it easy to turn, then turn the power back on and try to start the saw again. Be carefull because the saw may start. If the blade will not turn then the motor is definitely defective and will have to be replaced.
Good Luck!
Mar 14, 2011 | Craftsman 10" Table Saw
My delta table will not start. I just used it yesterday. I don't understand. The power source is good. What is it?
Hi, check the motor for any external reset. Some have this, and others have the internal overload. If the motor is cool and its been off, it must have tripped the overload. Find the reset and your back in business!! Good Luck.
Shastalaker7
Mar 11, 2011 | Saws
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I moved my delta table saw from one place to another and it is not the same i notice that it is much less powerful i conected the same way it was before i would like to know whst could be wrong.
Make sure you didn't go from a 220 power source to a 110 source. Longer extensin cords, especially smaller gauge cords will reduce power to the saw. Harder on the motor too.
Jan 14, 2011 | Delta Saws
While cutting , i experienced a bind. Before the saw stopped I shut it off. Left overnight, now will not restart. I have pushed the thermal reset button, however it does not seem to engage. I have checked...
Is this a direct drive or belt drive saw? If belt drive, you can remove the belt and try spinning the motor by hand then turn it on. Sometimes they can get stopped in a dead spot. Do not get your hands/fingers in the way when turning it on. You may need all of them someday.
Aug 08, 2010 | Hitachi C10FL 10" Stationary Table Saw...
DEWALT 740 ARM SAW.SAW STOPPED AND WON'T RESTART.POWER AT PLUG IS GOOD IS THERE A INLINE FUSE SOME WERE?
There is no fuse, and I am no electician...however, I had the same issue and a friend and I took the on/off switch apart, and discovered that it is some sort of "dual" type and it was/is defective. He said it could be jerry-rigged and work as a single switch, but I never did get around to fix it. I was actually looking to source the defective part (if possible), when I found your question. Good luck to both of us.
Grant
May 23, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How to reset a 740 power shop radial arm saw. Saw stopped during a cut. Breaker is good. Power source is good. Can find the reset button.
Hi Welby:
My saw is not a DeWalt, but the procedure should be similar.
First, WORK SAFE! UNPLUG THE SAW.
Now you can explore without the prospect of having it bite you.
Here are the things I would do:
1) Set the On/Off switch to OFF
2) Have a look at the motor. There should be RED (typical) reset button. When you find it give it a good solid push.
3) Check to make sure the On/Off switch is still OFF.
4) Plug in the saw.
5) Try turning it on.
If it does not work, I would unplug it and use a continuity meter to start checking the various components, especially the On/Off switch. If it has failed and you can't get a replacement you could
do as I have with an old Craftsman. It is 110 or 220, and has only been used on 110. Half of the switch terminals had arced over 40 years of use, so I just re-wired the switch to use the other terminals but still be 110. .
Feb 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
Oct 06, 2009 | Craftsman 10" Table Saw
Table saw Types
Portable table saws perform many of the functions of larger stationary table saws but have a decided advantage in their mobility. High mobility makes them the perfect choice for framing and deck building. They're also a good choice for small shops with limited space. Stationary saws added power enables the saw to run knives and cutters designed to mill and remove large amounts of stock and usually accept more accessories than portable saws.
Aug 27, 2008 | Dewalt DW745 10" Compact Job Site Table...
Delta 36 982 10 Inch Left Tilt 1 1/2 Horsepower Contractor Saw With 30 Inch Biesemeyer Fence, Table Board, And Legs, 115/230 Volt 1 Phase Logo
257 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
John Trevino
Are you a Delta Saw Expert? Answer questions, earn points and help others
