Question about Kenmore 54701 Dehumidifier
3 year-old machine. Appears that the main refridgerant supply line to the coils ices up soon after you turn it on, starting near a small canister of some kind, then the ice makes it way across the evaporator assembly (obviously following the line). If allow to keep running, the ice eventually pushes up and out the frame of the cabinet. The de-icing feature either doesn't turn on at all, or if it turns on it doesn't work. This is the second of this exact model of dehumidifier that has failed after no more than 3 springs/summers of use.
  • cappy13 Mar 11, 2011
    I just figured the first unit was a lemon, and kept it for parts and bought the same thing. What to do with a leak?
    Brigadier General:
  • 4,736 Answers
Often times, a clogged filter will cause them to freeze up. Because, it's not getting enough air into the system to warm the coils. If you haven't cleaned the filter recently or regularly, that is more than likely the problem. Other than that, the ambient room temperature can play a role in it. If it's cooler than 41 degrees, the humidifier struggles. Same is true if it's over 93 degrees.
Hope this helps you solve the problem.
Posted on Mar 11, 2011
  • 4 more comments
    I posted in my original submission that I have cleaned everything that can be cleaned, and that the fan is working. The dehumidifier is in a room that is 70 degrees.
  • Rich Landrum Mar 11, 2011
    Sorry, didn't see anything in your original post, that I answered, that said anything about you having cleaned it. In any event, now it sounds as if you may have a small refrigerant leak. Especially, since it's creating that must frost/ice. You said you had the same problem with a previous unit. Was it ever determined what was wrong with it? I'm hoping there's a clue somewhere with it. But, I still hold with the minor refrigerant leak. Please advise. Thanks.
  • Rich Landrum Mar 12, 2011
    Cappy, the only thing you can really do, is check all the refrigerant couplings/fittings for tightness and for leaks. Use warm soapy water to check for leaks, especially any couplings you can get to and can clearly see. Generally, refrigerant leaks (other than at couplings) aren't repaired, the coils are replaced. But, I'm not sure that would be DIY undertaking. The other issue, is getting the parts. Of course you have one on hand that did the same thing. But, would those parts be any good, considering the other unit did the exact same thing. So, you may want to seriously consider, buying a new one. But, another brand, obviously.
  • cappy13 Mar 13, 2011
    Thank you for taking the time to help. If the cooling system itself is leaking, that should be covered under the 5-yr. warranty (it is on the cooling system only, not anything electrical).
  • Rich Landrum Mar 13, 2011
    Yes, Cappy, you should be covered under the warranty. Hope it all works out for you.
What is causing ice build up on the coil bottom left? Whirlpool model AD50GEUSW dehumidifier?
Ice buildup is most often caused by low freon. Is the unit 10 years old or more? Might need a recharge. Turn it off and let it thaw then back on. If it ices up again, it likely needs a recharge.
Jul 09, 2017 | Whirlpool Dehumidifiers
There is ice on the filter and the filter will not come out. Tried turning off so it would melt, but filter still stuck. It is summer so why is ice forming?
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I had mine ice up once or twice particularly on very high humidity days > 90%. Once it thawed out. I was able to remove the filter. Most likely it is due to dust getting on coils & condenser Or actually has a Freon leak. to resolve the dirty coils you can easily dissemble (that is remove front & rear cover) it to give coils and condenser a good thorough cleaning. It the coils and condenser are not at all dirty, then is not the cause of the icing. The units are typically not serviceable - i.e. a disposable small appliance.
Jun 02, 2014 | Whirlpool 75-Pint Dehumidifier
Moisture collecting at the top front when running, even at mid power, over the control panel, sometimes turns to ice. if I shut it off when it is doing this the problem stops for awhile
Well, sounds like you have a good cold section in the dehumidifier-- that is good!-- But I agree-- we don't want water condensing on the surface-- and we surely don't need it turning to ice!
A couple questions to help us get to the next level of trouble shooting this problem:
1.) How cold is the room you are running the dehumidifier in?
(Obviously-- the warmer a room is, the easier to remove moisture--
the colder the room, the easier to drop the air temperature well below the freezing point-- making ice.)
2.) Have the air filters been cleaned/changed recently?
A dehumidifier needs a steady fast moving supply of air across its whole condenser/evaporator surface, in order to remove the maximum amount of water from the air, and not freeze up. (I would winder if something isn't blocking the flow of air toward the top of the coil?-- so that the coil in that area is going well below freezing temperatures, and thus allowing water (or ICE!) to develop near the top of the coil?-- Can you check air flow for us?
3.) You have suggested a good solution,-- especially if the above problems can not be easily corrected: Turn off the unit every few hours, and allow the warmth of the room, to defrost the coil....
In fact-- just to make sure that the air flow is not being restricted by ice deep within the coil-- let it stay off over night-- or bring the dehumidifier into a much warmer room, to make sure no ice is still blocking air flow deep within the coil..
Let us know what you learn about air flow, and get back with us-- THen maybe we need to take the trouble shooting deeper insicde the device.
I hope this helps-- MB
Aug 22, 2013 | Comfort-Aire BHD-301 Dehumidifier
The coils freeze up after less than a half hour of running. It does not matter what humidity setting I use or if I select the 2 hour or 4 hour run cycle. B/c the coils are freezing up, the dehumidifier...
the coils freeze up for one of two reasons .. if air flow is blocked .. sometimes by dust buildup or fan bearings needing lube .. second if the fan is working properly then ice buildup can be caused by low refrigerant levels .. the proper charge produces a steady coolness across the entire evaporator (cold coil) .. as the level drops it tends to cool a small part of the evaporator way too cold .. that creates ice .. the ice blocks the air flow and soon the whole thing is blocked ...so check the fan first .. if its running properly and there is nothing blocking air flow then suspect low refrigerant.. that requires adding a saddle valve service port to the system to allow adding refrigerant .. often the problem is caused by the fan not working at all because of lack of lube in the bearings or a bad starting capacitor ..
Aug 15, 2010 | Goldstar DH504EL Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
Unit runs but no water collects in bucket. Unit is over a year old and has run continuously that whole time. Up till now it has performed beautifully. Is it just worn out?
Hi;
Your dehumidifier is similar to a refridgerator or air conditioner. It has a compressor and coils, and a fan. Basically, the unit has to **** in air with it's fan, and as the humid air goes across the cold coils, the humidity condenses in to water. If the coils are not getting cold, they won't condense any water, or if the fan isn't running, or the coils are dirty. If you check your unit over, see if you can tell if anything isn't working. Make sure the control knob is set at the highest setting. If the compressor lost it;s refridgerant charge, and won't get cold, it isn't probably worth fixing
Nov 23, 2009 | Whirlpool 75-Pint Dehumidifier
LG 65EL water not dripping to bucket
THE DRAIN LINE IS CLOGGED TAKE OFF THE HOSE FROM THE UNIT AND BLOW AIR BACK THRU THE UNIT,, IT IS NOT UNDER A PUMP SYSTEM IT IS GRAVITY, IF IT WON'T DRAIN IT'S CLOGGED
May 29, 2009 | LG LD65EL Dehumidifier
Dehumidifier -- LG LHD45EL
If everything is clean on the coils and the filter is clean it should work. I would contact LG because they have a 5 year warranty on these dehumidifiers. Make sure that you have your reciept. Usually what they will do is locate a shop near you and it can be serviced there. LG will pay the bill. Or if there is no local shop they will send you a service tag for your old unit and ship you a replacement unit. Contact LG and explain this problem to you. Everything should be covered under warranty still.
Good luck - Tech101
Jun 29, 2008 | LG Goldstar LD65EL Dehumidifier
Kenmore 54701 Dehumidifier Logo
99 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
