Question about Sharp LC-32SB24U 32 in. LCD TV
No audio on the HDMI output for a sharp LC32SB24U
  • ALGIS SALYS Mar 11, 2011
    Please provide more information,
    What source are you connecting to your television?(DVD/Cable box/Etc)
    What connection are you using with this source?(HDMI/RCA/Etc)
    I just also want to clarify that you HAVE and HDMI output on your TV and this is being connected to what device that you are not receiving audio?
    Thanks,
    Guru:
  • 868 Answers
Hu dueperdio,
I see that your HDMI on your LCD TV does not provide audio, I will be more than glad to give you details on your concern, please see below step by step details,
* Before we start lets make sure that the HDMI cable is connected to you Computer.
* On your computer Laptop/Desktop lower right you should see an icon for the audio or a speaker icon to be exact, right click on it then select playback devices.
* Once we have Playback Devices up on the screen you will see a list showing you your HDMI device, Speakers, and possibly a Realtek High Definition audio device.
* Right click on the HDMI device which should be the first on the list and cselect on set as default device to make audio work on you LCD TV.
* Once set check if Aduio comes from HDMI to your LCD TV if not you will have to restart your Computer, leave the LCD TV on, and wait for the computer to start back up.
this should make HDMI video and Audio work on your LCD TV,.
Note: the steps above will be the same if you will go back to using the speakers of your computer, you will just have to set the speakers as the default device to get audio from you Laptop speakers or if you have a desktop on your desktop speakers.
I hope that this will help you get Audio from your HDMI, have a nice day,
mvincentc
Posted on Apr 11, 2011
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
Which roku do I get for a sharp model lc32sb24u
I always get the 3 because it has the most features. I have three of them now, and they all work great. I think any of them will work with your tv as long as it has an HDMI input.
Dec 12, 2014 | Sharp LC-32SB24U 32 in. LCD TV
No sound from ps3 when connected with hdmi to sharp lc-42d64u lcd, connected to sony dav-hdx589w via digital optical cable
on your PS3 go setting>sound setting> audio output settings to adjust settings for the audio device (OPTICAL or HDMI)
Dec 05, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
How to set my audio to hdmi while connecting my tv to my pc. my graphic card is Gforce 9600
I am pretty sure that the nVidia GeForce 9600 series of video cards use a DVI connector, not an HDMI connector.
While the HDMI connector has the ability to transfer digital and analog audio across it, the DVI cable does not.
You can connect a DVI video card to an HDMI display, and it is compatible for the VIDEO portion, but again, the DVI connector does not output audio at all.
You will need to connect the audio outputs of your audio card or motherboard to your TV by using a 3.5mm headphone jack to RCA jack adapter.
Dec 08, 2008 | Sharp Audio Players & Recorders
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
HELP WITH CNECTION
Only if you've got an HDMI output on your computer. Some computers with higher quality video cards, or just newer ones will have a DVI output for a monitor. You can get a DVI to HDMI cable that will then be able to connect the two.
As others have said, if you have a video card with DVI output, you can get the video to the TV using a DVI to HDMI cable.
But no one mentioned anything about audio. DVI can not carry audio, so you'll need to send audio from the computer to the TV (or receiver). Some TVs have audio inputs associated to one (or more) HDMI ports for use with devices that have DVI, but not HDMI. My Sharp LCD has two HDMI ports, one with separate audio inputs, one without.
Sep 27, 2008 | Computers & Internet
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Setting up sharp 46
Try to isolate the problem.
Try plugging in another source such as a DVD, is there audio? If yes, problem may be with the optimum box. If no, most likely a problem with the TV.
Also, if you are using HDMI with the HDTV box, make sure the box is set to output audio through HDMI.
Feb 10, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Jan 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC-32SB24U 32 in. LCD TV Logo
393 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
