Question about Maisto Harley Davidson 1997 XLH Sportster 1200
I have 2001 sportster XLH1200 my bark plug is black and my front plug is clean what is the cause off this problem
  • 60 Answers
Is it running and idling OK?
You should not have a totally clean front plug. It should be tan, like a paper bag.
Do a quick/free check - It is possible that your front cylinder is running too lean due to an air leak. You can diagnose an air leak by running propane or spraying WD-40 around the intake while running. If you hear a change in engine speed, you have a leak. Tighten everything up, ride for a bit and check your plugs again.
If that's not it, the rear cylinder is not completely burning - not enough spark energy. If you have not replaced your plug wires in awhile, it's probably time to do so. Replace the spark plugs of course, and inspect the coil terminals for corrosion.
Posted on Mar 11, 2011
2002 harley electra glide front spark plug keeps turning black
The 02 that blacks front plug , Check front head and rings and barrel
Apr 09, 2014 | 2000 Harley Davidson XL 1200 C Sportster...
What would cause insufficient flow to my egr valve? (i just replaced it)
ok , the valve is easy to test and clean but is only 10% of the path.
my bark test works.
i remove the EGR valve see 2 ports there. (twin holes)
one is vacuum side, (intake) the other is exh. side.
i plug the vacuum side, and start engine
this is what i call the bark test. if the exh port barks load ,it may be good. if dead, or weak, it is, fix that now. clean path.
if that works ok , i then check the vacuum path port of carbon blockage. i rod it out with a flex cable.ask
the electric side test are below.
see 253mb file here
http://hondatech.info/downloads/Auto/Manuals/Accord/
that is the FSM. burn it to cd, and run the setup'
Jan 31, 2014 | 1999 Honda Accord
Gear assembly for 2003 harley davidson XLH1200
Hi Rocco, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Sep 04, 2012 | 2003 Harley Davidson XL 1200 C Sportster...
Green black white wires on sportster
Hi Nicholereneh. If they are just above the intake manifold they plugged into the air cleaner backing plate on California models. Good luck
Jun 15, 2012 | 2001 Harley Davidson XLH Sportster 883...
Torque Settings for XLH1200 sportster Harley Davidson
Hi Hoghall, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below and good luck. Harley Davidson Manuals Mark Workshop
Sep 20, 2010 | Harley Davidson XLH 883 Sportster...
I have a 1992 sportster 1200 xlh and need to know how the connecting rods are suppose to set in the flywheel. also need to know which side the spline on the flywheel should be
The connecting rods are known as "knife and fork" rods in that one rod sits inside the other at the crankpin. The "knife" rod goes to the front cylinder. The "spline" shaft you're talking about is called the "sprocket shaft" and goes to the left (primary drive) side of the engine. Try this site.
http://www.bikebandit.com/1990-harley-davidson-motorcycle-xlh1200/o/m1772
If this doesn't work, contact me directly at wd4ity@bellsouth.net
Good luck
steve
Aug 04, 2010 | Motorcycles
Replaced the clutch in my xlh1200 1995 with a kevlar clutch kit. when I put it back together I couldnt squeeze the clutch. I took off the derby cover and figured out that the adjustment screw was hitt
I would go back to scratch. Disassemble the clutch basket and reassemble it making sure you have it set in proper order. Then reassemble every thing. Also double check the clutches you bought are the proper ones for your bike.
Apr 25, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
Maisto Harley Davidson  1997 XLH Sportster 1200 Logo
83 people viewed this question
Top Maisto Toys Experts
ray gallant
Mai Lor
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
