I have an expire l100 when I hit the power button it starts the boot then shuts down immediately i see the fan start to move,then shuts down?
  • 519 Answers
A likely cause of the problem described is a faulty power supply. Try booting again with a different power supply. If this doesn't solve the problem you may have a faulty motherboard.
Let me know if you need any further assistance.
Best wishes,
Graeme
Posted on Mar 11, 2011
My computer continues to shut-down for no apparent reason while booting up. It will get to bios then abruptly shutdown. Please Help!!
Maybe something is defective from the factory? Can you bring it back and exchange it for another? Is it a desktop or a laptop? If it's a desktop, maybe remove a side panel and aim a small fan at the inside. Do you know how to start up your computer in safe mode? Maybe try starting it in safe mode and see if you can do a system restore, do you know what that is and how to do it? Google will explain it to you, but I'd suggest those steps.
Mar 21, 2017 | Gateway Fx Computers & Internet
ACER ASPIRE X1200 Unexpected Shutdown
When does it shut down? Are you able to use it at all? Or does it shut down when you are trying to boot it up?
When it shuts down are you able to boot it right back up and start using it? If not, it might be running hot. If you let it sit a while to cool off then try booting and if you are successful, then it is definitely running hot.
Three things that will make a computer run hot.
1. Dust - Dust inside the computer, dust clogging the vents and fans. Dust around the cpu and heat sink. To fix, Remove the power cord, remove the case and take a can of compress air to blow out the dust.
2. A fan is not working. Make sure the fan inside the Power supply and the fan that sits on top of the cpu is working. Normally the system will notify you if the fan is not working. To fix, you will have to replace a fan that is not working.
3. The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool. To fix, apply a fresh coat of Thermal Paste around the cpu and heat sink.
Maybe you have a virus or infection that is shutting you down if it is not running hot and you are allowed to work on the computer for a while before it shuts down. Boot the System in Safe Mode and see if it shuts down.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode With Networking option (this will give you internet connectivity) and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. Download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
May 24, 2012 | Acer Computers & Internet
GT4016 hit pwr button comes on flashes three
Check the USB ports for damaged contacts. If the supply powers up and then shuts down immediately, you have a critical error. Damaged USB port contacts can cause this but so can graphics cards etc. Open the machine up and remove all cards and memory sticks and unplug all the drives but LEAVE THE CPU ALONE!! Now, turn it on. If it boots and starts beeping ( which it will with no memory installed) shut it down and reinstall each item you removed one at a time and turn it on after each single thing. When it stops booting and does whats its doing now then the last thing you plugged back in is the issue.
If it still doesn't power up with everything removed then the issue is in the mainboard. If this is th case, my advice is to seek professional advice..
Dec 02, 2009 | Gateway GT4016 Desktop PC
Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
Nov 18, 2009 | Acer Aspire L100 PC Desktop
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Toshiba Satellite A55-S306 doesn't come out of hybernation
Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
T6420 E-Machine won't/Reboot W/O F8 Key
No sync means no video signal to the monitor. The rest sounds like a corrupted OS. This could be from a number of reasons, including a virus. If you have NORTON or MacAfee, Your open to a lot of attacks. Get AVG free, and use Mozilla instead of IE.
The reason the fans come on full speed is the MB senses a high temp on the CPU, until the bios fan control takes over after POST. This is normal on most systems.
Aug 22, 2008 | E-Machines eMachines Desktop PC
Computer shutting off
because of virus you start windows in safe mode an try booting if it work in safe mode > go to run > type= msconfig > disable all in startup, reboot windows see if it works if not please reinstall windows xp.....
Apr 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mike
Mar 29, 2008 | ASUS A8V-VM Motherboard
Computers & Internet Logo
David Payne
David Payne
