Question about Philips Magnavox 15MF400T 15 in. LCD Television
Philips magnavox tv model # 15mf400/37
Tv was working fine all of a sudden one day turned it on and no light no picture no sound, nothing...
had cable wire for basic tv no box, so i took cable wire off and plugged into regular outlet and still nothing???
No i havent a solution yet. am waiting to hear from Philips support & Customer Care by email or phone. I cannot afford to pay you people just to ask a question that i probably could not understand the answer anyway. I know my tv just stopped working and I think it was the manufacturers problem. Like i said it was not an old tv.
thank you anyway
Posted on Aug 01, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
My 1996 Magnavox 25" TV won't work
It sounds that the tuner to your TV is faulty. A detail check is necessary to confirm. Seek expert tech support.
Jun 20, 2012 | Philips Magnavox 13MT143S 13" TV
TV has sound..no picture Philips DPTV335 was working fine and suddenly picture went out. Still has sound but nothing on screen (volume bars, picture)
This is a projection TV. No picture can have a whole host of causes.
When the TV turns on, you can see background dimly but no picture.
Caused by the picture being muted. Perhaps the video signal is too fast - 1080i on a TV that does not support it might cause this.
Menu works but no image.
Definite picture muting. A bad video cable, no video from the device providing the picture. From the tuner, the signal circuit board needs repair.
No background, no image, no menu
This is a loss of high voltage to the picture tubes. If the picture cannot draw up and down or side to side, this will happen. Definite time for a repairman. Can be pricey if certain parts have blown out.
Most likely is a loss of vertical drive. (up and down drawing of the picture)
Mar 21, 2010 | Philips Magnavox MWR10D6 DVD Recorder
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
When I turn on TV I get a message no video input. We never use video with this tv. Only have it for looking at satelite. The other main tv is working fine. I pressed all the buttons but nothing works.
Sounds like the input accidentally got changed. On the remote that came with the TV, push the INPUT button until you get your satellite picture again. If your SAT. remote is programmed to your TV, push the TV button, then the input button until you see your picture. If this doesn't work then the sat. cable is not securely attached or no longer works.
Aug 30, 2009 | Philips Magnavox 27MS343S 27" TV
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
Phillips magnavox
Could be an open internal fuse or power supply failure
Mar 18, 2017 | Philips Televison & Video
Will not Turn On
It is a problem on the main board and could be the regulator IC or Horizontal output transistor.
Regulater IC should be a STR53041
The HOT is marked on the front
Be sure to check the 100mfd @50v cap next to reg IC
and the transistor on the left N4923
Jul 17, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 15MF400T 15 in. LCD Television Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
