Question about Vacuums
The piece under the blades cracked can it be replaced with out buying the whol blender
    Sergeant:
  • 259 Answers
You can try removing the blades and put apoxy in the crack and let it dry. Put the blade back on and make sure the blade does not rub by turning the blade by hand to see if it turns smoothly. Do all of this while the blender is unplugged.
Posted on Mar 11, 2011
GE blender model 169169 jar broke, trying to find out where to buy replacement picher (glass)
I have the jar since my motor base stopped working. Make me an offer and I'll mail you the blender jar. Tom
Sep 03, 2011 | Vacuums
How do you remove the coupling on model kichenaid ksb560mco. it doesnt spin off like some online instructions say.
It should spin off when you stop the motor from turning. Use a long flat bladed screwdriver positioned against one of the teeth of the coupler on the angled side of the tooth. Then hit the screwdriver with a hammer to drive it into the plastic tooth without breaking off the tooth. (Note: it's a left-handed thread, not the more common right-handed thread. So you need to turn it clockwise to loosen.)
The hard part is getting that motor connection to stop turning with the coupling.
If you want to save the coupler and some damage to the blender when the screwdriver slips, get the blender coupler removal tool. See http://www.kitchenaidblog.com/blender/kitchenaid-blender-rubber-coupler-9704230-with-removal-tool/ for a link to buy both. Slide the removal tool under the old coupler to hold the knob from turning. Then turn the coupler to remove it. For some a pair of pliers helps you start the coupler moving. (It can get stiff over time.)
I hope this helps.
Jun 26, 2011 | Vacuums
How do I replace the blades on my magic bullet
Here is a link for E-Bay that has several blades for sale:http://shop.ebay.com/sis.html?_nkw=MAGIC+BULLET+PARTS+ACCESSORIES+BLENDER+MUGS+EXTRACTOR
-OR- If you purchased the original blender bullet less than a year ago, your device should be under manufacturer's warranty and you should be able to get replacement bullet parts or a new unit. If you are one of the lucky ones, contact Homeland Housewares at 1-866-4HOMELAND (866-446-6352), their customer service is available Monday through Friday from 9am to 8pm, from 9am to 4pm on Saturdays and from 10am to 4pm on Sundays, Eastern Time -PLEASE READ FIRST THOUGH- http://www.magicblenderbullet.com/Replacement-parts.htm
Hope this helps. Thanks for choosing Fixya, RJ
May 15, 2011 | Vacuums
Our shredder (Wilson Jones 1200) now has a very high pitched squeak when we shred anything. Really high pitched. We can't see if there's anything stuck (ie a staple) Is there a number we can call for...
https://www.wilsonjones.com/us/us/2723/contact-us
* First, I'm not a Wilson Jones tech.*
*** the following are for information only. ***
* Our friend keeps dropping off shreader after some problem with them. She always buys a new (different) one and leaves the junk to tinker with. These are some of the common problems I've encountered.
* Not moving. Totally jammed with paper! I had to use a blunt tool to back out the wheels. Careful as the blades are very sharp! It's best to use a wooden dowel to edge the blades back in the direction to loosen the stuck paper (be sure to unplug shreader!)
* Cracked case or inner frame. If it cracked under normal use then there is a design flaw or something fell on it. Only a complete swap out of equip will work as any glued on plastic parts will break again under load.
* Sensor is knocked off or damaged. Again, too much paper. Replace unit.
* Squeeks are caused by paper, staples, plastic (CDs) getting caught between the wheels and comb. Reversing helps, but some have to be physically removed. Again, unplug and check for the stuck debris. Remove with tweezer or needle nose plier. Careful of sharp blades!
* Squeeks will usually stop after a time as you continue to use the shreader. Debris will wear out and drop. Just keep in mind that whatever was shreaded when the squeeking started. That item should be avoided and only shreaded in small quantities at a time, alterating between regular paper.
* Check with the MFR if there is a lubricant, spray that is required. I use silicone spray sometimes when I have a lot of shreading to do. (Check with MFR)
* Final; Commercial shreaders tend to be large enough to get your hand or clothing stuck in the machine. Call for service to be safe.
Aloha, ukeboy57
Feb 22, 2018 | Vacuums
Fan blade cracked
It needs replaced before it breaks and pieces get into the motor.
Replacement instructions can be found at http://www.ehow.com/how_5534689_replace-fan-kirby-vacuum-cleaner.html.
Jan 03, 2011 | Kirby G4 Bagged Upright Vacuum
How to put bottom blade of blender back after cleaning
Drop blade in from the top.there should be a notch that blade fits in or it should screw into bottom piece that drives the motor of blender
Oct 21, 2010 | Vacuums
Motor burned out need a replacement motor. Where can I buy one?
USAVACUUM.COM has all the hoover parts available for the H3000. The part number is 59177074. Follow the link below to your model number.
http://www.usavacuum.com/category-s/85.htm. .
Thanks. Please leave positive feedback.
Mar 13, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Got this blender in 83 and the pitcher is cracked. Model 600-1. Can I get a replacement?
You may be able to get one from the manufacturing co. or you may find a blender with a pitcher that fits at a yard sale, flea market, thrift shop or Good Will. However, blenders are not that expensive and after 26 yrs you may soon need a new motor. Now may be a good time to replace it. If its sentimental, keep it but get a new one.
Nov 03, 2009 | Vacuums
Cracked
I'm afraid that you will have to replace the base unit, part #62577, would sell for around $25. Once it cracks, then it is weak and will affect the brush roll and belt.
Dec 30, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Vacuums Logo
120 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
