I have a Denon AVR-1908 and would like to hook up a wireless transmitter to some wireless speakers on my patio. Could I use the zone 1 and zone 2 feature? If not how do I hook this up?
  • 3 more comments
  • randy_gilles Mar 13, 2011
    That didn't work. I have a set of wireless speakers from audio unlimited and would like to hook up the transmitter to my avr-1908 so I can listen to the same music inside our house and also out on the patio at the same time or maybe an A/B switch might work so I can zone them. How can I hook them up? It should be simple right? I need your help.
  • randy_gilles Mar 14, 2011
    The front jacks are for v.aux input connectors. It doesn't look like I have any PRE OUT connectors. Is what I'm trying to set up possible? I hope so. What about the zone 2? Do I have to have another amp to make that work? If so what do you recommend? I would like to keep it simple. Thanks for your help in advance.
    Thats weird. My Denon AVR model # 1908 does not have those pre out connections below the speaker connections. What should I do? Is there another way to hook them up?
    I purchase this at a best buy. So if that is the case will the manual that came with this Denon refer to mine as well? I have had this for about 4 years now. Should I take it back?
  • randy_gilles Mar 17, 2011
    It looks like I have a 1908 by the manual and went on line with Denon and it matches the one I have. It's almost identical to the picture you sent me with out the pre outs. Because I have a zone one and zone two, how can I hook up zone 2 to this wireless transmitter? Will that work? I hope we can work this out.
  • 11,800 Answers
In a wireless speaker setup the final amplification of the sound is done in the speaker itself . Because of that you will have to connect the transmitter to the PRE OUT front jacks and you will not be able to use Zone 2 - only Zone 1 is active on them - so you will always get on the patio speakers the same output as on the main ones.
Posted on Mar 12, 2011
  • 3 more comments
  • Azrael SRL Mar 13, 2011
    The only way to get an audio signal from that receiver is from the PRE OUT L and R RCA connectors - if you don't get a signal out of them then you are not connecting the transmitter correctly. If it has an 3.5 jack you will need a RCA to 3.5 adaptor for it to work.
  • Azrael SRL Mar 14, 2011
    This is how the back of the Denon AVR-1908 looks like
    http://www.son-video.com/images/static/R...
    Right below the speaker connector are located the PRE OUT ones. So yes, it's very much possible and very easy to do: just plug the emitter in the FRONT connectors.
    Then most surely you don't have an 1908, most likely it's an 1905 that has been labeled as an 1908 - i heard they did that to some of those sold in US in Walmart and similar shops.. In that case all you can try is the CD-R/TAPE OUT connectors, but the level in there is lower so the sound will be lower in the secondary speakers.
    1905 is a lower generation than 1908 - fewer features but the same general characteristics so yes, the manual will match. This is a common behaviour in US in bargain shops - to lower costs the devices are simplified but are still sold with the same model number. So no, you can't return it for that even if it would have been brand new, let alone after 4 years - when even the warranty has expired a long time ago.
  • Azrael SRL Mar 17, 2011
    You cannot hook them to any speaker output so the zones don't matter. All you still have left to use are the CD-R/TAPE OUT connectors, nothing else will work.
Zone 2 doe's not work Ihavetwo speakers that are outsde they are zone 2 when a am to the tuner I press zone 2 ad it shut off
Possibly a shorted speaker wire? If you remove zone 2 does the amp still shut down? If not, connect one side at a time and try it. Do you see the word protect on the display when it happens?
Aug 04, 2014 | Denon AVR-1908
The Denon does not play any source on the speakers, just on the headphone jack in the front. What could be the reason?
You might want to review the manual below:
http://www.usa.denon.com/AVR-1908-OM-E_109.pdf
1) Make sure MASTER VOLUME is not set too low 2) MUTE should be OFF 3) Make sure nothing is plugged into the PHONES jack 4)Make sure the source program has a signal present - the inputs may not be connected to the selected source on the front panel (or try FM or AM for a source instead) 5) Check for proper connection at each of the speakers AND at the rear of the stereo. 6) Perform a microprocessor reset: a.Power the unit off, b. Press and release the "POWER" _while_ keeping both "Speaker A" and "Speaker B" buttons pressed. Once the display begins flashing in 1 second intervals, release both speaker buttons.
Hopefully, one of those steps will solve the issue. Please rate this reply if it was helpful - good luck!
Jun 30, 2010 | Denon AVR-1908
Denon AVR-1908 speaker issue
Before we play taps and throw dirt on top of the Denon, perhaps a bit more triage is in order. I'm not certain who the patient is. Especially when you have "speaker issue" in the title. Are you saying there are some speakers that don't work ONLY with BluRay?
If it has NEVER worked the (unnamed) BD player or its cable(s) could be at fault, too.
What 'connections' are we talking about. HDMI, coaxial- or optical audio, 5.1 analog; to what input on the Denon assigned to what function?
Have you tried all audio paths out of the BD player? Is it configured to squawk in the right digital mode?
Do you have any other digital audio sources (CD/DVD) you could use to certify the audio paths that don't work with the BD player?
Apr 08, 2010 | Denon AVR-1908
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
Denon AVR 1609 volume Zone 2
Logitech recommends that zone 2 is controlled using device mode on your Harmony remote. Controlling zone 1 and zone 2 simultaneously within activities may lead to the AV Receiver turning on and off unexpectedly as you switch between activities. For example, if you try to turn on zone 2 within an activity, it may turn on or off zone 1 and vice versa. Controlling zone 2 in device mode will prevent this from happening.
Aug 07, 2009 | Denon AVR588 Receiver
Can't get the MultiZone to work on my Denon AVR 3805 Reciever
No as there is no volume control on the zone outputs
Aug 18, 2017 | Denon AVR-3805 Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Problems getting Zone 2 to work with TV and DVD player
You may want to take receiver into a repair shop. I had the same problem, not useing a wireless transmitter. My denon has been in the shop since Jan 9th. There is a problem with zone 2.
Dec 17, 2007 | Denon AVR-2307 Receiver
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
