Question about Imperial IR-36-LB-C Gas Single Oven
Oven temperture limit to 325 f ,won't go higher
My breville oven now takes 40 min to heat to 325 degrees. Even longer for higher tempos. Is there something I can do to fix this problem? 3 years old. Thanks
Bet that one of your heating elements is open. Identify defective unit and replace.
Check out site for parts and availablity. Search Over 2 1 Million Appliance Parts
Sep 02, 2017 | Ovens
Whirlpool RBS245PDS18 temperature calibration?
If it is new contact the people that sold it to you for warranty repair. If not Just set it higher, that is a lot lest costly then getting the appropriate equipment to calibrate it. You can also replace it.
Dec 19, 2014 | Whirlpool Ovens
Why oven does not reach temperture
what's the model number?
May 20, 2014 | Kenmore Ovens
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
I set the oven at 350 degrees and after 3 hours it has only reached 185 and won't go any higher. The oven is approx. 8 years old.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 25, 2011 | Ovens
GE jvm140k prchase 1993. Oven timer works and displays time and progaming but oven won't start up. It has been working off and on but now won't work at all.
The model you gave was for a microwave oven. In the backside of the microwave is a air cooling window. If it gets clogged with junk the mag will overheat and the limit on the side of it will shut down the oven. Simply cleaning this area so that air can circulate better can cure the problem. I suspect it finally got so bad that the cavity thermal limit has blown now and you have nothing at all.
I have a service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 27, 2011 | Ovens
High limit switch trips and needs re-set
After grilling or cooking at higher temps leave the oven light on so the cooling fan continues to run for approx 1/4 hour, or whatever setting will keep the fan running...
Apr 22, 2010 | Dacor ECS130 Epicure Electric Single Oven
My oven reaches 350 then stops
REPLACE THERMOSTAT AND TEMPERTURE PROBE
Apr 28, 2009 | GE JTP20 Electric Single Oven
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 | Ovens
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 28, 2008 | Ovens
Imperial IR-36-LB-C Gas Single Oven Logo
35 people viewed this question
Top Imperial Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
John Rodgers
John Rodgers
Are you an Imperial Oven Expert? Answer questions, earn points and help others
