Question about Garmin nuvi 255W GPS Receiver
The GPS just stopped working, it does not turn on. I plugged it into computer USB and it still does not turn on. Thanks for your help.
  • 464 Answers
Try obtaining another power cable and see if that is the issue, yours may be dead and not charge the unit. also some USB ports dont have enough power to charge/power a GPS so that may be what effecting that. If this dosent work i would recommend purchasing a new unit as your is not worth sending in for repair.
Hope this helps!
Posted on Mar 11, 2011
When GPS plugged into the USB port, the computer, it doesn't seem to recognise it.
First, try plugging it to another USB port on your PC, if the same error appears, try using a different USB cable. If no luck the try it on another PC If you can get in to the device manager and delete the usb drivers, and drivers for the hard drive, then reboot the computer and reconnect again, it should reload the drivers and that may work..
Oct 31, 2011 | Tomtom One XL GPS Receiver
How do i update my gps
A GPS will help find the shortest and fastest routes to a particular destination. When the maps are out of date, the GPS may not be able to find the best route. A GPS should be updated at least once per year. Some GPS manufacturers will allow the user to download free updated maps; however, many manufacturers require the user to purchase updated maps. Updating a GPS map isn't complicated, and will take about 2 hours to install.
1.Turn on the GPS and plug the USB cable into the USB slot located on the GPS.
2.Plug the other end of the USB cable into the USB slot on the computer.
3.Insert the map update DVD into the computer. If you have a map download, locate and open the file on the computer.
4.Click on Update Firmware located on the main menu. Click "OK" when the firmware is finished updating.
5.Unplug the USB from the computer and turn off the GPS. This will allow the firmware to reset on the GPS. Turn the GPS back on and select the language and time.
6.Reconnect the USB to the computer and click on "Update Map," then click on "Load Maps."
7.Connect to the Internet by clicking on the activation link. This will display the activation number. Find the serial number located on the back of the DVD. If you downloaded the update, a serial number was provided. Enter the serial number and activation code into the update program to continue updating.
8.Close the program after it has completed the update, and unplug the USB from the computer and the GPS. Turn off the GPS to finish the update.
I hope you find it very helpful. Thank you for using fixya.
Aug 20, 2011 | GPS
DO the Garmin receivers work with Windows ?
Yes the Garmin DPS units do work with Windows. There should be a USB cable in the box the GPS came in. The smaller end plugs into the GPS and the larger end into one of your computer's USB ports. The GPS screen should come on and show the Garmin name. Then the Loading Maps title should show briefly. A graphic should show up on the bottom part of the screen that looks like a desktop computer connected to a GPS. A horizontal white line should then appear about half way up the GPS screen which should turn to green. You should then be able to see your GPS listed as a removable drive in Windows Explorer, or whatever file management program you use.
If you are unable to see the GPS unit there is a plug in available on their website called the Garmin Communicator Plug-in which should help you see the GPS unit in Windows or your internet browser. IF you still cannot see it then try and switch to another USB port on your computer. If you have anything already plugged into a USB port and your computer can see the item, then try and plug your Garmin into that port. If you still cannot see the unit then there may be something wrong with the unit or your cable. If you still have a warranty you may want to take your unit back to the store you purchased it from. Windows should definitely see the unit without having to load any special driver.
Mar 06, 2011 | Garmin nuvi 1450 GPS Receiver
Device no longer being picked up on a computer when connected via the USB
The device will act just like a USB drive when connected.
Remove GPS from computer, switch it ON then OFF.
check the cable is plugged into the computer USB ok.
If your computer is windows OS check that the device manager is not showing any errors in the USB ports.
If all ok. Then replug in GPS.
If that does not work, try another USB device or try GPS on a different computer to see if its your computer or the GPS.
Please dont forget to vote this answer was helpful.
Many thanks
Feb 15, 2011 | Tomtom Go 530 GPS Receiver
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
I just bought a Garmin 265WT. I ran the registration program, but the computer does not recognize the Nuvi. I've checked My Computer and it does not show a new drive ( the Nuvi should like like a drive...
Try these steps:-
  • Unplug the USB cable from the computer.
  • Turn the unit off and then back on again.
  • Plug the USB cable into your computer.
  • The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
Also, in some cases the operating system does not support the device. Try upgrading it to the next higher level. In most of the cases windows Xp service pack 2 does not recognise this Garmin device. Try upgrading it to service pack 3.
If you are still experiencing the problem then you will need to contact Garmin for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 12, 2010 | Garmin nuvi 260W GPS Receiver
I have a Garmin i5. I have used it for years but on a recent trip it just stopped working. By this, I mean it won't turn on. I tried switching batteries several times, and the reset described by holding...
try plugging it in to the usb port on your computer, then if it starts, install the batteries.
if you did not get a usb cord with your gps, pretty much any usb to mini usb cord will work.
bill
Oct 12, 2009 | Garmin StreetPilot i5 GPS Receiver
I just received my Garmin for XMAS and it was working fine but now it just seemed to not charge. Then the little pic on the front shows the GPS connected to a computer desktop. HELP! Amber Fader
Does it turn on at all? Try to charge it on car adaper then, when it will turn on, try this.
The picture is displayed while it is charging through USB cable and you can't normally use GPS.
Turn the GPS on without the USB plugged in, then press the Battery symbol for about 10 seconds, until the test screen appears. Then plug in the USB.
Screen will tell you percentage of charge, and if it is charging.
***Make sure you press EXIT before unplugging the USB cable. Press EXIT, turn GPS off, then remove the cable is safest way
On the bottom you should see "USB type" if nothing is there, it may be the USB port on your computer. Try it again with a different port
Jun 12, 2009 | Garmin nuvi 255W GPS Receiver
My GPS won't turn on.
I had this issue also. When I got it out of the box, it had maybe 30 minutes of playtime without a charge before the battery went low. I used the USB it came with and found plugging it into my laptop AND desktop does absolutely nothing; even though the magellangps.com states the USB can be used as a charger on the PC.
It's been less than 8 hours since I've had it, and I have not gotten a chance to use the car adapter to charge it... I have a DC/AC unit inside my house which I am using to charge the unit and it works fine (incase you dont know what a DC/AC adapter is; its pretty much a lighter adapter that plugs into the wall).
MAKE A LONG STORY SHORT -
With my migraine starter experience with charging and powering on; I have read on 100's of Magellan 3250 reviews that cold tempratures cause these issues.
Other possible causes:
Battery is 100% dead = leave it in your car charging (HIDE UNDER THE SEAT!)
If the USB port plugged in charging in the car; if it is still not working, make sure that the FM part is also plugged in. I found that my GPS does not charge with just the USB end plugged... At least for me, it will only charge with BOTH ports plugged....
I hoped my novel helped... If it didn't; return your Magellan, and buy a GARMIN GPS. I have a Garmin that I bought for my hubby, and 2 years later, has never once experienced any issues.
May 09, 2008 | Magellan Maestro 3250 GPS
Garmin nuvi 255W GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
