Question about Ovens
My Univa U236SS countertop stove,oven has stopped working. It worked well the previous day but all of a sudden it stopped working. The oven temp light comes on, but no function on the oven works. The element does not even heat up. A while back we noticed the countertop as well as the controls are very hot while the oven is on. No smell of something burning though. The 4 plate stove top still works fine.
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    SOURCE: MY HOTPOINT SELF CLEANING STOVE
    how do I get my self cleaning to come on in my hotpoint stove
    Posted on Oct 13, 2008
    TheMobilian
    • 8220 Answers
    SOURCE: Oven appears to start, takes forever to preheat,
    This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
    Posted on Feb 26, 2010
    Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
    SOURCE: need wiring diagram univa stove /oven model ph14s
    Were do I get the skimatics for a stoves wiring as I have to put the regulater back to geather as old one fell apart.
    Posted on Oct 28, 2010
    heatman101
    • 43501 Answers
    SOURCE: My oven does not work. The stove top does work.
    If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
    Oven Problems Electric Oven is Heating Slowly or Poorly
    heatman101
    Posted on Dec 14, 2010
    1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
    Thermador Appliances ' Frequently Asked Questions ' Use ...
    www.thermador.com/faq/categories.php?categoryid=53
    ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
    Thermador Range/Stove/Oven Parts - RepairClinic.com
    www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
    Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
    [PDF]for Thermador Professional Series Built-in Wall Ovens
    www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
    Dec 19, 2015 | Thermador C272 Electric Double Oven
    The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
    Go to appliancepros.com and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
    Apr 23, 2014 | Maytag Ovens
    I have a bush AE56DW oven bottom oven was working, but now only the fan works and there is no lights or heat coming out?
    have the very same problem on my bush stove though have just found the problem out, on the oven switch looking inside has all the wires but what hidden and needs taking out it s fuse near the knob and cannot be seen until taken out and your see this thermal fuse blown this stops all power to inside stove light no power then to thermostat oven temp everythings dead,
    ive tested everything untill ive looked at replacment parts and then your shown a fuse of 240 vol when do they put this in such a place clear to have use all have to call out an engineer, ive beaten the system
    Apr 05, 2014 | Ovens
    GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
    The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
    If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
    How it works: Silicone Carbide Ignition
    XL44 gas stove manual
    Jan 25, 2011 | GE Ovens
    Hi there i have a stoves newhome double oven the bottom oven has suddenly stopped getting hot the fan and light are still working but we have no heat.we have tried changing the thermostat but that has not...
    If the fan is working o/k, then I would suggest that bthe oven fan elementt has failed.
    This is usually located at the rear of the oven compartment behind a removeable cover.
    Dec 28, 2010 | Stoves Ovens
    Need wiring diagram univa stove /oven model ph14s
    Jan 22, 2010 | Ovens
    Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
    whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
    Jan 16, 2010 | Ovens
    Oven burns things, very hot on bottom
    The temp indicator light goes on and off according to the temp selected.
    The sensor referred to is part and parcel of the the thermostat, or temp selector
    the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
    Dec 21, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Ignition wont stop while oven is working
    Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
    Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
    Ovens Logo
    41 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
