Question about Remote Start System
2001 jeep grand cherokee /viper 5101 rs with keyless entry all wires are hooked up properly as far as im concerned but remote start will not activate i have a 7 flash diagnostic code
    Problem Solver:
  • 7 Answers
I'd say the easiest thing would be to stop being a lazy tw@ and get into the vehicle with a key as normal. Come on, lose some wait...
Posted on Mar 11, 2011
Viper 5101 no longer starts
are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
Apr 17, 2014 | Remote Start System
NEED HELPPPP with 94 Jeep Wiring
Check out a web site called NAXJA (North American XJ Association) it's a Cherokee forum.
May 21, 2013 | Denso 1994 Jeep Grand Cherokee Laredo 4.0L...
How do you program a keyless entry remote for 1998 Jeep Grand Cherokee
someof them you cant you have to take it to the dealership
Jan 17, 2012 | 1998 Jeep Grand Cherokee
2002 jeep grand cherokee with valet remote start. when remote start is activated jeep starts then shuts off immediatly
Apart from the inginition wires ( you must check if there are 12 volts), the alarm needs to read the tach reading properly from the car to stay running. If the tach rate is not learned by the system, it will cut out almost immediately. You need to ensure that this tach wire is connected to the tach under the hood. When this has been connected, you need to ensure that the alarm learns the rate. This can be done automatically on some models or manually on others. Ensure that the appropariate wire is connected to your tach wire; it should work properly after that
Jan 02, 2010 | Directed Dei Valet 561r Remote...
How do i program my keyless entry remote for my jeep grand cherokee 2001
The dealer would have to do this. Or you can rent a DRBIII at techautority.com and it will guide you through the program.
Oct 25, 2009 | 2002 Jeep Grand Cherokee
My keyless remote for my 2000 jeep grand cherokee wont unlock the
go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Jun 03, 2009 | 2001 Chevrolet Blazer
Flat battery.
There's something in the manual that says to use the keyless entry or to run a lock sequence in the driver's side door - try locking and unlocking the doors after cables are hooked but BEFORE turning the ignition to see if that releases it.
Oct 31, 2008 | 2001 Jeep Grand Cherokee
Remote Start System  Logo
302 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
