Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
1TB USM hard disk not being recognized - Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Cant see my passport external drive on new windows 8 laptop
Try unplugging from usb and plugging it back in. Also, you may need a SAS driver for your computer to recognize the drive. Some drives have internal encryption and require a driver before the computer recognizes them. Check the Mfg website to see whether this drive requires one.
Jan 03, 2014 | Western Digital 1TB My Passport Essential...
Seagate 1tb hard disk not recognized
This is a hardware problem but since you can't access to the removable you have to order a new one making sure the warranty of your product is still valid
Aug 05, 2017 | Seagate FreeAgent Pro 1TB External USB...
I bought a 3.5 External hard drive enclosure for a 1TB hard drive. The PC recognizes it but not under the removable drives
right click on "My Computer" and select "Manage". Then go to "disk management" once loaded you will see your drive. You probably have to initialize the drive and assign it a drive letter. all that can be done from right there.
Aug 09, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
Disk has no format
Does the disk show up under My Computer? If so then right-click it and select "Format Disk" and format it in NTFS. If it does not view this link and follow the instructions to get that disk active...http://support.microsoft.com/kb/309000
Jun 05, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I can't see the hd symbol. I have a brand new external 1TB hard disk. Windows xp recognizes the device but it doesn't show the system symbol, thus I can't write on it.
Check the Disk Management console to see if the hard disk is partitioned and formatted.
Right-click My Computer and select Manage in the popup menu.
Dec 18, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
My computer fails to identify my WD 1tb external hard drive when I plug it in the USB. It also does not show up on Disk Manager. However, it still lights up and I hear it turning. How can I get the...
I fixed that problem with a WDC My Book Home 1TB in Windows 7:
The drive was recognized in computer management and in device manager but no drive letter was allocated while connected with a e-sata cable.
1.in computer management > storage > disk management
2.rightclick drive 1 or wathever the number of the WDC drive (which should be basic at this time)
3.select 'convert to dynamic disk'
4.drive should get a drive letter
5.format (warning: all data get lost, but you can download original software from wdc.com)
Succes!
Olivier
Oct 31, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Ps3 and 1tb hard disk
This one may only have one possible solution.
You probably have heard that the PS3 will support up to a terabyte hard drive. That is true for most of them.
However, depending on the version of PS3, you may have to see if it is possible to flash the BIOS of the PS3. I talked to a Sony representative about the hard drive and it will support a 1 terabyte hard drive.
Contact sony to see if it is possible to flash the PS3 BIOS so it will recognize the drive.
Jul 27, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
MY 1TB Western DIgital Ext Hard Drive is not recognized
Go to add new hardware wizard. This may not come with a disk if you do have a disk it will ask you to put disk in. If you do not find it there go to the HCL directory of the western digital website for installation directions.
Jun 04, 2009 | Western Digital My Book Essential 1TB...
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
Jul 31, 2008 | Cavalry Storage Cavalry CADB001U32 1TB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
51 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
