Question about Garmin GPSMAP 276C GPS Receiver
I have mapsource loaded but while all works I cannot see any roads on the maps.Is there a special setting I have to make ?
    Sergeant:
    Champion:
  • 232 Answers
Get your self a maual for that Garmin,,,If the answer isnt covered there,,,,,Google the same question and end up on a Garmin forum where others are talking about the same problem,,,Als see if Garmin has a toll free number for trouble shooting your unit.
Posted on Mar 11, 2011
Chat session ended by mistake. I need help with getting my Garmin GPSMAP 60 CX up and running. 1. I have successfully loaded Trip and Waypoint Manager on the computer 2. I have the unit hooked up to the...
You cannot load maps to the unit using the Trip and Waypoint Manager software. That software only does what it's called - it transfers routes and waypoints. To install maps onto your GPS, you will need Mapsource, which normally comes with the maps. Once it's installed on your PC, you hook up your GPS with a mini-USB cable, choose which maps you want transferred to the unit, and then the Mapsource software will knit the map segments together and transfer them over to the unit. Hope this helps.
Jan 06, 2011 | Garmin GPSMAP 60CS GPS Receiver
Have just received my garmin gb topo dvd and the 8 letter code would not work. used a 25 digit code and it said i had unlocked it ok but my garmin etrex keeps saying cant unlock maps? any ideas?
I have had this problem before. You have to make sure you have the proper map data selected in Mapsource before you start selecting data to download to the GPS. I had multiple maps loaded into Mapsource but they weren't all unlocked for the multiple GPSs that I own. if I got the licenses mixed up between the units it wouldn't work. There should be a setting in your option menus.
Feb 12, 2010 | Garmin eTrex GPS Receiver
Need a Map Source CD for a Garmin iQ 3600 GPS
Please visit http://www.ebay.com
Search for the needed item and there you are.
rate this solution afterward.
Sep 04, 2009 | Garmin iQue 3600 GPS Receiver
HOW DO YOU LOAD MAPS TO THE GPS UNIT?
You will need to load the MapSource software on your PC then load the maps into MapSource. After the maps are loaded and unlocked you can plug your GPS into your PC with the USB cable and load the maps.
Hope this Helps.
Jul 24, 2009 | Garmin eTrex Legend GPS Receiver
Need to change garmin zumo550 from NoAmerica to Europe mapping.
On my Garmin (another model but still) all changes to the installed maps are performed through the Mapsource software. You activate and deactivate what you want to have installed and then use the transfer function.
Make sure you have enough memory for the maps you need to have installed, maybe you need a little memory card like 2 GB or so, Mapsource should tell if there are any problems though.
Maybe your machine uses other software but I doubt it.
One more thing: I found it to be extremely much quicker and reliable to do the transfer directly onto the SD card through an USB adapter than through the cable, for some reason the cable slowed everything to a fault-prone crawl.
May 25, 2009 | Garmin MapSource Roads & Recreation Europe...
Garmin street pilot i3
after i send the map with mapsource from first minnutes is not seen the detailed maps what were transferred but after the receiver catch signal it apears my map detailed
i put gmasupp.unl file to garmin folder from microsd with key from keygen 1.5 i dont know if its necesary but its working with road 2008 romania @ europe nt v9
Mar 26, 2009 | Garmin nuvi 200W GPS Receiver
Street Map Program for Garmin GPSMAP 295
Detailed road map data, with addresses, hotels, gas stations, etc. can be loaded into a data-card/cartridge/memory-card using Garmin's Mapsource software such as Metroguide or City Navigator. This can be changed as needed via a PC.
The 295 does not have driving routing/guidance through the streets as most of today's GPSs have, but it will show you exactly where you are on the street (but it should be switched to Road mode).
Driving routing is possible on the PC using Mapsource, but ithe route doesn't transfer well to the 295 because of the limits on waypoints.
Nov 29, 2007 | Garmin GPSMAP 295 GPS Receiver
Map problem
There are two type of maps in the unit. There is the basemap which shows the states and major highway and roads and then there is the actual Mapsource maps which shows the streets. If you go to Mapinfo and it doesn't show anything, then Mapsource maps are missing.
With the 2610 you can use a card reader for the Compact Flash Memory card to load the maps. This is much faster since the card reader is USB 2.0 while the Garmin USB is 1.1 Under device look for the drive letter which correspond to the Campact Flash card.
Oct 15, 2007 | Garmin StreetPilot 2610 GPS Receiver
Route calculation error
I was having the same problem and contacted Garmin support.
What I had done was turned off the Basemap that came with the unit. I only had the mapsource map street map on which I had purchased separately.
The technician basically said the unit needed the basemap to "locate itself". Somehow the basemap supports any maps you purchase separately. That seemed odd but once I turned the Basemap back on it calculated the routes and the error message went away.
If you have the Basemap off, try turning it on from the Map Setup - Information window.
Hope this helped.
Oct 01, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
Garmin GPSMAP 276C GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
