Question about Car Audio & Video
OK the radio randomly shuts off and on when the face is up but works fine with the face down. is this from a faulty switch ? if so what is it, were can I get it and were Is it at on the radio?
  • mustangfunk Mar 11, 2011
    it is a Pioneer DEH-P6700MP. sorry I thought it was at the head of the posting.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
First of all, it would help if we knew what kind of radio it is. a make and model would help tremendously.
Posted on Mar 11, 2011
  • 1 more comment
  • kenw392
    kenw392 Mar 14, 2011
    try cleaning the contacts on the face and subpanel with either qtips and rubbing alcohol or a pencil eraser. also, is the face snug up against the subpanel when the face is closed?
  • mustangfunk Mar 14, 2011
    it kinda moves around. it is not umm... as snug as the glove box door in the car.
  • kenw392
    i'm not sure, but you may want to check all of the screws on the subpanel and make sure they are all tight. the latch that holds the face on to the subpanel may be loose also.
My 2002 chevy malibu's radio seems to be shorting out, the radio will work fine but randomly the sound shuts off the radio still shows the radio station and even says which artist is playing but there...
I'd suggest using the balance and fade controls to cut out each speaker one by one. to possibly determine if you have shorted speaker or speaker wiring. As far as the turn signal clicking noise, the hazard switch is the actual flasher unit for the turn signals, and could be the culprit, but the most likely cause is the turn signal switch itself. It is usually caused by corrosion across the contacts, which can be cleaned out fairly easily, but more typically, the switch is just replaced
Jun 16, 2011 | 2002 Chevrolet Malibu
Cobra 29LTD speaker inop....No audio at all. Speaker Ohms out ok as do speaker leads from board to speaker. External speaker jack is inop. PA works in PA and CB modes. Other than speaker issues, radio...
There are some different things you could be facing like:
the speaker sound being cut-out by the mic switch, but my first guess is the switch in the external spkr. jack being faulty. Here is a schematic for you.
http://xbones_antennas.tripod.com/id21.html
Apr 12, 2010 | Cobra 29 LTD CB Radio
1990 525i Dash Freak OUT!!??
it sound like a faulty ignation key contact. it is a common problem of 5 series E39 model. I hope it can help you this tip. thanks
Jan 23, 2010 | BMW 525 Cars & Trucks
TV shut off randomly. Unplugged for a while, worked for 2 minutes then shut off again.
Hi.
Random shut down can be caused by faulty power adapter, faulty inverter and faulty controller board, add buttons, shorts, bad fan and IR sensor.
The TV must be tested to find out the problem.
I suggest contacting Sanyo by calling the number listed on the owners manual.
Parts and part price available here.
Nov 19, 2009 | Sanyo DP19649 LCD TV
Pc keeps randomly powering off & then back on. Won't stop until I unplug it.Holding down power button won't shut it off. On occasion it will stay on - is able to boot & be used normally while it...
Power supplies usually are culprits in random shut downs, but random start ups is a bit more complicated. You say that when you hold the power button, the computer won't power down. Perhaps you have a faulty switch? Make sure your PW switch cable is securely attached to the motherboard. But I'm leaning more toward a faulty switch or a short in the wires. Seems like a good place to start.
Sep 05, 2009 | E-Machines eMachines Desktop PC
Same thing
this unit needs a mechanical alignment, I have worked on enough rca's to last a lifetime...the cd tray is not chucking properly//it should load and you should hear the cd mech chuck down..if it is not chucking properly..it will open randomly..you can fix this by jamming it shut with the power off
Jul 28, 2009 | RCA RS1289 Shelf System
Laptop shuts down randomly
I should check that you do not have a virus. That is typical behaviour of some virus infections.
Jun 13, 2009 | Computers & Internet
Drop down face problem
try resetting it by pressing the little button on the front of the face
Nov 29, 2007 | Dual XDMR-7700 CD Player
USB port randomly not working
Sounds like dirty contacts on the radios faceplate. If this radio is a flipdown face style then I'd suspect the contacts on the back of the faceplate that connect to the radio when you close the face. Cleaning agents vary from pencil erasers to rubbing alcohol...
Jul 28, 2007 | JVC KD-G720 CD Player
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
