Wireless speaker components not working - Audio Players & Recorders
  • 17,130 Answers
Please recheck to see that all the connections are correct. Remove and refit all the connections.
Make sure there is power to the master remote/detect section.
You have not mentioned the make/model to clarify further..
Posted on Mar 11, 2011
Sub woofer will not work
Check the speaker of the sub=woofer. If found OK, check and replace the damaged component/s at its audio output section circuit. Contact any service technician. Electro help
Apr 04, 2015 | Samsung HW-FM45C 280W Soundbar with...
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 25, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
Crackle or popping from EV Sx 100+ speaker
test this : Gd bless you
Line noise is feeding in from the AC line. Use an ac line filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 10, 2013 | ElectroVoice Audio Players & Recorders
Won't do anything! push power protector keeps coming up, what to do?
One of the speaker outputs are burnt,need power board replacment (audio output board, not power supply) don't replace components on board since is very difficult
Aug 23, 2011 | Sony BRAVIA® DAV-HDX277WC Theater System...
What is the power supply for these speakers
Connection Type
While standard speakers connect to your computer with a wire, some speakers are made using wireless technology and do not require running wires to each speaker.
AOpen manufactures computer components and has more than 22 years of experience in the PC industry and over 700 patents in PC technology. To be successful, each component must work flawlessly within a broad range of other computer products. Understanding this, AOpen dedicates its engineering expertise to the production of components of quality, durability, and the utmost flexibility MS-608 Pro is a state-of-the-art 2-piece speaker set. Ideal for PC, CD-ROM, DVD it features 160 Watts P.M.P.O., single volume control, bass reflex cabinet, magnetically shielded design, and more.
hope this helps
Aug 12, 2011 | AOpen MS-608PRO Computer Speakers
Rear S-Air speakers cutting in and out
I read on another review that the HDMI cable is causing this problem because it is beside the S-Air transmitter on the main unit. I could not get my rear speakers to pair or work, and sure enough, when I removed the HDMI cable and hooked up the unit via Component Video to my Sony 52" XBR TV, the speakers paired and worked. When I plugged the HDMI cable in they did not work. I am going to try to purchase a higher-end, more expensive HDMI cable and see if that helps. The whole point of HDMI is for true blue ray 1080p pictures. Hope this helps.
Feb 16, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
We have the sharper image wireless indoor outdoor speaker and when we plug everything in there is nothing coming out of the speaker. Are we able to get it to pick up satellite radio?
The wireless speakers do not pick up a wireless signal outside of the round wireless broadcaster that came with the speakers. You will need to connect that to your satellie radio to broadcast to the wireless speakers. Make sure the wireless broadcaster component is plugged into the sound source you want to make wireless. After you've connected the broadcaster to the sound source and turned everything on then push the Auto tune button to connect to the broadcaster and recieve the sound.
Nov 27, 2008 | Audio Players & Recorders
Partial theft
As far as replacing the dvd any dvd player will work, as far as your LCR speakers go ( left, center, right ) it would be best to replace them with the same ones that came with the whole system, at least you want them to be same in size, power, and manufacture relative to the 2 rear speakers, at the very least the replacements should be same in size and power relative to the originals even if not from same manufacturer so as to attain relative level balance with the rear speakers, at the very very least any LCR replacement speakers will do really. The main point is keeping the relative balance between the LCR and rear speakers, the sub can be adjusted on its own. Sorry to hear about your theft by the way, that sucks.
Aug 04, 2008 | Bose Lifestyle 28 System
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
My panasonic wireless surround sound won't work out of the Rear speakers
I have finally got my rear speakers to work. wireless internet or cordless phones will stop the speakers from working, i switched off my wireless internet and hey presto speakers work fine, i just cant have both at the same time.
Jan 20, 2007 | Panasonic DMR-E50 DVD Recorder
13 people viewed this question
 Grubhead
Grubhead
