Question about Whirlpool Washing Machines
When using the delicate setting, the clothes do not get fully spun dry. In addition water has leaked out of the machine and the water did not fully drain. Again only happens on the delicate setting
  • 1 more comment
  • helmstetter2 Mar 11, 2011
    The switch is fine. The machine drains properly on all settings but delicate. Should I call in a repairman? Or as I told my wife just don't use the delicate setting...
    The switch is fine. The machine drains on all settings except delicate
    Thanks
    Brigadier General:
  • 3,513 Answers
Hi
Be sure the drain hose isn't kinked. Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
The water pump may be broken or clogged with a small article of clothing, or the controls may be broken;
Also check this link bellow related to your issue if it helps:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=#theresnodelicateorregularspinoragitate
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 11, 2011
  • Aparajita Batabyal
    Aparajita Batabyal Mar 11, 2011
    Hi
    If the washer will drain in all cycles except delicate then check the motor and timer for the cause of the problem. If the washer will drain and spin in other cycles but not delicate then the timer is most likely at fault. You can check this by your own or call a repair person for thorough check up.
    Hi
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
Easy and correct wash dry instructions
Just as I suspected, this is made out of synthetic materials. [main body] Invista Lycra, [compression] PWX FLEX, [panels] Powermesh
I suggest that you set it on "hand wash" setting on your washer. If that is not available, use "Delicate" or "Gentle" cycle. If you don't have a washing machine, best thing to do is hand wash it. Fill a clean sink with water, add a little bit of gentle detergent (many different brands are available and labeled as "gentle care". I use Seventh Generation, which can be bought at regular grocery stores and even Target!
And then hang dry it. Dryers ruin clothing especially manmade materials. I typically hang something at night and it is dry by the morning. Also recommend hanging your top in the bathroom as the enclosed area has a greater deal of circulation/ air flow than other areas of the house.
Seventh Generation
Nov 24, 2015 | 2XU Mens Black Short Sleeve Compression...
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
My ecosmart GWL11 Fisher and Paykel washing machine is leaking water from the bottom, I think during the spin cycle, but am not sure--there is a puddle of water when I come out to put clothes in dryer. ...
Double check your drain hose is both attached and that there are no splits in the hose. I have found that even the smallest split/hole leaks huge amounts of water. If the hose has come off you will obviously need to reattach it, if it is split i found it best to replace rather than repair the hose.
Oct 25, 2010 | Washing Machines
Water left in machine (clothes dripping) after delicate cycle
Whirlpool is best in the standards of top loading washing machine when you are going for the front loading you can buy the IFB washing machine to get the better result
May 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water
its probably normal as new machines now only put in enough water to saturate the clothes its only the rinse or wool/delicate cycles that use a higher water level
Mar 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
