Question about Samsung HM250HI 250 GB SATA Hard Drive
Its a 250 gig hard drive and its saying that the memory on the hard drive is a 14.9 gig hard drive. it won't allow for it to put windows 7 back on it. It says there are no drivers on the hard drive on setup
    Guru:
  • 592 Answers
This hard drive needs to be repartitioned and formatted first then you should see actual amount. You can do this when selecting the drive in windows 7 installation
Make sure the drive is listed in the BIOS matching your serial, model number, etc incase you purchased this from ebay or second hand.
Posted on Mar 11, 2011
    Guru:
  • 811 Answers
What I would do in this situation is a complete format of this drive to where it is totally blank. Active Kill Disk is what I use, the software will allow you to do a complete format. You will also need to download utorrent free torrent software Click Here This is what you need to download torrent files.
It is obvious that the drive is filled up somewhere. And you need to do a complete format. Bringing it back to its 250 gig capacity. Then install Windows back on it again. Making sure it is set to Master the settings on the front of the hard drive that show which jumper setting for the drive set it to Master. The master drive is common for Windows installs.
Now the other possibility is that the hard drive is bad or corrupted. This is possible. If that is the case then you will have to replace the drive if it will not take after a complete format. Lets hope this is not the case. Please do not forget to vote for me, thanks for using FixYa! John
I replace 250 gig to 500 gig. can it affect the processor, hard disk drive and other parts of my laptop?
No it won't BUT the BIOS may not support a 500 Gb hard disk, it will see it as a smaller capacity hard drive.
Oct 17, 2012 | HP Pavilion dv6000z Notebook
When I plug my seagate free agent go portable hard drive (250 gig) into my usb, it register's that there is a device pluged into the computer (give's me the DING, that window's is famous for) but say's it...
try a different usb drive. if you are using win 7 or vista uninstall that device driver you downloaded. if its xp re install your usb drivers from the windows site just go to your device manager
win 7 vista click on computer sys prop device manager see if drive is connected hit update driver or roll back. same with usb system on win xp right click my comp. go to prop, then device manager let me know if this helps. but really important to make sure that you are plugged into a usb port in the back of the pc not thru a hub
Mar 16, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
When I plug in my Lacie external hard drive to my computer, it freezes up the Computer window when I am browsing my drives. Eventually it shows up, but shows that it has no files on it and doesn't say how...
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 03, 2010 | LaCie (300770) 250 GB Hard Drive
Will pass bios but then will not load windows, will not boot from CD, will not boot in safe mode. Tried reinstalling windows, will not, I can't start so can not use system restore. Will not boot using the...
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Oct 13, 2009 | Dell XPS M1530 Laptop
Upgrading from 250 gig hard to a 500 gig hard and says mismatch. my first hard drive is dead
hi pete,
changing the bios will do the trick, find one that is most compatible with aspire 1640 for a 500gig hd, once you have this replaced, it will work.
for more laptop troubleshooting tispd, you may also check the link below.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Acer Aspire L100 PC Desktop
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Thank you for your help last time
256 mb of memory is not very much. It's the bare minimum you can get by with running Windows XP. Adding more would certainly be an improvement.
Only 1 gig of free space left on an 80 gig hard drive is not much room for Windows to work with. I would definitely try to get rid of or back up some files to make more room. You should also run a system clean up and do a defragmentation of the hard drive.
You should keep your anti virus software up to date if you have one installed. If not you can go HERE and run Trend Micro's Houscall on your PC. Viruses and Spyware will bog down a system and cause it to run extremely slow.
Jul 04, 2008 | Computers & Internet
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Hard drive backup
Dear aspec,
First u try to perform scandisk the lap hdd. you also confirm wheather the bios is fully supproting the 250gb drive.
Tapa
(91-9830114059)
Samsung HM250HI 250 GB SATA Hard Drive Logo
258 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
