Question about Williams (5009622) Ceramic Gas Wall Mounted Panel Heater
My new gas wall furnace has a problem with the pilot light staying on. Any ideas?
    Guru:
  • 683 Answers
Is it a standing pilot light?
Posted on Mar 11, 2011
4 Suggested Answers
  • 80 Answers
SOURCE: pilot light will not stay lit on model 465FX-R
It is possible that gas valve is bad, however, try replacing the pilot orifice located in the pilot assembly. If the flame is inadequate it will not generate the voltage required in the thermocouple. Pilot orifices are less than $10 and can be found at your local heating contractor's parts counter. Bring in the orifice to match.
Posted on Oct 03, 2009
billyvangogh
  • 108 Answers
SOURCE: Wall furnace shuts off after about 10-20 mins
sounds like its not venting properly...it likely is shutting off on a "Spill switch" or "Vent safety switch"....check the vent/chimney first off.....also the pilot could be dirty..,..a lazy pilot tends to blow out easily....pilot should be blue and sharp,,,big enough to fully envelope the thermocouple
Posted on Nov 01, 2009
Testimonial: "I checked the pilot light and it's clean. I will have to check the chimney next week but thanks!"
  • 59 Answers
SOURCE: Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Posted on Oct 22, 2010
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Pilot light will not stay lit; replaced the thermocouple, still no work. Replaced the W/R gas valve 36C04-222 on my Trane furnace. Still not working. any ideas? Could I have gotten a bad replacement valve?...
Trane unit ,same White -Rogers gas valve. I have replaced both the gas valve and the thermocouple . Have agreat robust blue pilot while the button is pushed in , let go and the flame does not stay lit . I checked the milly D C volts and have better than 20 . Is there a problem with the new gas valve or the couple not generating enough volts or is there a safty I do not know about that could be open ?
Dec 15, 2010 | Heating & Cooling
Relatively new wall furnace suddenly stopped working.
if you are by passing stat at the gas valve and it is still not working,i would assume a bad control valve.
Jan 13, 2010 | Heating & Cooling
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
Oct 30, 2009 | Heating & Cooling
Pilot Light won't stay lit on wall furance
The low voltage wiring and the thermostat has noting to do with the pilot function of the wall furnace, check to see if when you have the pilot lit manually, while holding the button in does the flame impinge on the thermocouple and does the flame try to wrap around the thermocouple? if not the thermocouple and pilot flame need to be adjusted so that it impinges on the TC, if it does have a good flame impingment, then you probably have a bad TC from the factory, call them and have them send you a new one if still under warrenty.
Jan 20, 2009 | Williams 1403622 Gas Compact Heater
Nov 08, 2008 | Cozy (W352E) Heater
Unable To Keep Pilot Light Lit!
I have a Williams top vent gravity wall furnace (model 5009622) and I had the same problem. I had to take the cover off the furnace -- screw on top and two at the bottom (open the access door and there is one screw on each side) to get to the reset button for the vent safety shutoff system. On my furnace it's on the left side toward the top of the unit. I pressed the little red reset button and it's been working ever since. If your furnace is properly installed and doesn't have bird's nest in the chimney, it should work fine. Good luck!
Mar 04, 2007 | Williams 2509612 Ceramic Mid-Size Heater
Williams (5009622) Ceramic Gas Wall Mounted Panel Heater Logo
430 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
