Question about Intel S875WP1-E Server Board Motherboard
Need the pin settings for scsi led header for intel sever board s875wp1-e
  • 1,940 Answers
SCSI Hard Drive Activity LED Connector
The SCSI hard drive activity LED connector is a 1 x 2-pin connector that allows an add-in SCSI controller to use the same LED as the on-board IDE controller. For proper operation, this connector should be wired to the LED output of the add-in SCSI controller. The LED indicates when data is being read from, or written to, both the add-in SCSI controller and the IDE controller.
Test the 2 pins using a multi-meter to determine which is + and which is -. Nowhere in the manual does it say which is which.
Posted on Mar 11, 2011
Download e139761 manual a10383
An old Intel entry server motherboard, that uses a Slot 1 Intel processor,
http://www.ebay.com/itm/Intel-S875WP1-E-Entry-Server-Motherboard-E139761-D33025-Free-Shipping-/321064089691?pt=US_Server_Boards&hash=item4ac0e9385b
Over by the white IDE connector on the Right side of the motherboard, (Motherboard installed in computer case), there is a 9-pin Front Panel header.
It is the usual Intel 9-pin Front Panel header,
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/
Regards,
joecoolvette
May 01, 2013 | IBM (73P0595) Motherboard
How to connect power switch to mother board
http://www.intel.com/support/motherboards/desktop/dg41rq/sb/CS-029925.htm
Click on -
Intel Desktop Board DG41RQ Product Guide - English (PDF)
Bookmarks menu to the left -
1) Click on the + sign to the left of -
1 Desktop Board Features
Click right on - Desktop Board Components
Or go to Page 11. (Adobe Reader page number box at top)
Front Panel header location marked by P, in the figure.
2) Click on the + sign to the left of -
Connecting to the Internal Headers and Connectors,
in the Bookmarks menu.
Click on - Front Panel header
Motherboard mounted in computer case, the Front Panel header is in the bottom/right corner, above the top black SATA connector.
Two rows of contact pins.
The Top row is numbered EVEN.
Starting at the Left side going across to the Right, Top row;
Pins 2, 4, 6, and 8. There is NO pin 10.
The Bottom row is numbered ODD.
Starting at the Left side going across to the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Probably 5 Volts DC for factory testing.
D) Pins 2 and 4 are for the Power On LED. (Light)
This IS for a -> 2 wire LED. (Light)
Pin 2 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
To the left of the Front Panel header is a 3-pin header.
This is the Alternate Front Panel LED header.
If you have a -> 3-wire LED, it connects here.
Also wanted you to have the motherboard manual.
Regards,
joecoolvette
Nov 04, 2012 | Intel DG41RQ Motherboard & Core 2 Duo...
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
I've got an Intel server entry board S875WP1-E and I've set the BIOS how I need it. Now that the jumper's been put back to normal operation there seems to be no boot up action from the board. The...
While the power is off at the wall. remove the BIOS battery for about a min, then reinstall in the correct orientation. Power on at the wall socket and turn on. Was the board working before you flashed the BIOS?
It is possible that the BIOS is now currupt and therefore doesn't work go to www.badflash.com for more information.
They may be able to replace your BIOS chip.
Your timeous rating of this solution is much apperciated.
Thanks
Nov 01, 2010 | Intel Server Board S875WP1-E Motherboard
Gateway / eMachines 4006149R, D102GGC2 Motherboard
Their should be a 9 pin header at the bottom right corner of the board. Between the sata headers and the corner. There are two rows of pins in the header, one row has 5 and the other 4. The row with 4 pins has the power switch and the power led pins : : : : . They should be color coded red for the switch and green for the power led. From left to right the first pin is for the led (+) lead, the second pin is for the led(-) lead, the third pin and fourth pin are for the power switch. Also there is a 2 pin header above the 9 pin header that is an alternate power led header, the left pin is (+) and the right is (-). I hope this helps you.
Aug 26, 2009 | Intel Computers & Internet
GOT NEW BOARD NEED TO WIER IN FRONT PANEL THE REST IVE DON
You can download the manual from Intel here. Jumpers and header functions are all described there.
Mar 20, 2009 | Asrock K7S41GX Motherboard
I need the front panel pinout for an Emachine T2984 motherboard
Here is the pinout for several Intel MB's with 845GV Chipset.
Mar 18, 2009 | Intel Computers & Internet
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Front panel ceonnctor
Intel® Desktop Boards meet the ATX motherboard design guide specification using a 9-pin front chassis header. Special attention is required when attaching the front panel connector from the chassis to the Intel desktop board.
Front Panel Header
Description Pins Hard Drive LED 1 - 3 Power LED 2 - 4 Reset 5 - 7 Power ON (Power Switch) 6 - 8Lou
Aug 25, 2008 | Intel D845GVSR Motherboard
Need specs on ax6b mb
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
ASIC: Intel 440BX AGP set
Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
Max. Memory: 1 GB SDRAM for DIMMx 4
DIMM Type: 8/16/32/64/128/256 MB
BIOS: AWARD plug-n-play flash ROM BIOS
On Board I/O:
2 serial ports (UART 16C550 supported)
1 parallel port (SPP/EPP/ECP supported).
2 floppy drive supported (1.2/1.44./2.88 MB)
2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
2 USB ports supported (universal serial bus)
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
Battery: 3V lithium battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
Board Size: 244 mm x 305 mm, ATX form factor
Apr 13, 2008 | Computers & Internet
Open Questions:
See all Intel S875WP1-E Server Board Motherboard Questions
Intel S875WP1-E Server Board Motherboard Logo
114 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
