Question about Marantz CDR631 CD Recorder
MARANTZ CD PLAYER/RECORDER MODEL#CDR500/U1B
THIS MACHINE DOES NOT RECORD FROM ANY SOURCE.THE TECHNICIAN SAYS THAT THE MOTHERBOARD IS DEFECTIVE AND WOULD NEED REPLACING.PLS HELP ME FIND ONE. I have gleaned the following information from the board and I hope it means something :
- ELEC-1
- E330BM
- ELECIE-07B/06616MM04914276
  • Marantz Master
  • 19,396 Answers
Contact
Marantz
to get original replacements
Posted on Jul 31, 2008
  • Ginko
    Ginko Jul 31, 2008
    In USA :
    Parts Support hours:
    9:00 AM to 5:00 PM ET, M-F
    Tel: 201-762-6392
  • Ginko
    Ginko Jul 31, 2008
    call 201-762-6392, give model number to them and they will ship the part, if you live in a different country use Marantz website to find part contact, under support.
My marantz cd 7300 reads no disc probably needs a new laser, where do i get one, thoes sold on ebay look different, many thanks, Peter.
This sounds crazy but it works for some reasons. Marantz CDR500 would not read and initialise some blank discs but no problem with reading finalised ones and erratic would and would-not work. Tried cleaning lens and even blowing ar through it. Before I wasted money in air I thought why not try hairdryer into open tray and lens area and just for measure across blank CD. I know this sounds weird but it worked every time and machine will read any make of disc like this. I do not have any scientific explanation only the fact that it works!!!
Nov 23, 2013 | Marantz Audio Players & Recorders
I have a de recorder 4050 when I try to put a track of a vinylalbum on cd, it stops after 20 seconds what can I do about it?
YOU mean "CD" recorder, right? A recorder will typically stop recording in the extended absence of audio.
And the track that is recorded - what does it sound like? If it's silence then you need to track your source back to its origin through the undefined electronics and find out why the signal isn't getting through to the recorder.
Jul 27, 2011 | Marantz DR-4050 2-Disc CD Recorder
The player wont record. All other functions fine including playback and finalising.
You mean it records silence? if it finalises then it does recognise and burn to the disc- so the laser/drive seems to be ok..
If silence, bear in mind there are analogue, optical and coax digital inputs to chose from for record source
Don't forget too these units need the special CD-R audio discs not CD-Rs to record to.
Oct 19, 2009 | Marantz DR-700 CD Player
CDR tray
it's more than likely the servo board which is fixed under the mechanism.
this is very common but i'm not sure which component fails on the board but i've always got hold of donor recorders and switched the servo boards and all was fine.
Sep 06, 2009 | Marantz CDR500 2-Disc CD Recorder
CAN,T DETECT CD IN BURNER TRAY
laser failure on the recording side is very common on marantz and philips cd recorders.
they're well known for it.
so it's most definately the laser in your case.
hope this helps.
Jun 19, 2009 | Marantz CDR500 2-Disc CD Recorder
I cannot get the CDR510 to record from an external source. At first impression it appears that the analog line-in jacks don't work.
make sure you have the recorder source control turned up and the external device in the input or aux. be sure the external source is sending a signal and not padded or turned down
Dec 04, 2008 | Marantz CDR510 2-Disc CD Recorder
CDR is not working
have a look on ebay for a cheap working donor recorder as spares are very expensive and very hard to get hold of.
i'm guessing your recorder either doesn't read discs, or it won't eject? which is very common and means either the servo board is faulty or the laser.
The following recorders i know off hand for a donor mechanism are:
MARANTZ DR-6050
PHILIPS CDR-775
PHILIPS CDR-770
if it proves to be just a faulty laser, all 3 of the above have the same laser unit.
if it proves to be a faulty servo board, all 3 have the same servo boards except if you fit one out of a philips model it will show 'PHILIPS CD RECORDER' on the display at power up but will still work nontheless.
obviously if a marantz is found it will show 'MARANTZ CD RECORDER' as normal.
hope this helps.
Aug 27, 2008 | Marantz CDR500 2-Disc CD Recorder
Dfsfd
cdr keep open when power it on.
May 29, 2008 | Marantz CDR500 2-Disc CD Recorder
Marantz CDR420
Simply switch the analog to digital button on the front to analog, turn off the machine and turn it back on.
Oct 09, 2007 | Marantz CDR420 CD Recorder
Marantz CDR631 CD Recorder Logo
220 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
