Question about Bazooka EL1500 Car Audio Amplifier
Hey i dont know to much about amps, but me and my friend (he knows a decent amount about amps) would plug the power into the amp and the green light would come on. Though when we plug it into the subs, the green light would turn to red or it would stay green and the speakers still wouldnt be getting any power.
  • Bazooka Master
  • 637 Answers
Check your speakers to see if they read correct ohms.
Posted on Jun 20, 2014
    Sergeant:
    Novelist:
  • 185 Answers
Are you connecting positive to positive and negative to negative from the sub to the amp? If so, try positive to positve (+) in the far left channel and then the negative to negative (-) on the far left channel to. If no luck do the same in the other channel with one sub at a time. Try one sub at a time, Dont try an connect 2 or more subs to one channel as this would cause the amp to go into protect mode (red light you describe). Usually the positive wire has either a line down the wire, writting on it or has a red seperate wire with it when wire end stripped to connect it. Hope this helps and please rate...
Posted on Mar 11, 2011
I brought a rover mgzr and want to put radio in it but the wires in the loom have had the connectors cut off so i just got the speaker wires and the four wires to power the radio, I know which speaker...
My assumption would be black = earth, red/black = power, purple power antena? green white? start by getting a test lamp put the earth ********, turn ignition on & check all wires for power also test in acc position & off position in case 1 is memory (constant power) once you know which ones are power put the test light in the power & black to check the black is the earth. Once you have + & - & speakers it should work.
Jun 27, 2012 | Cars & Trucks
My amp jl audio 500/1 i connect it and the green light turn on then i turn in the sterio and it sounds but when i turn off the sterio and when i wanna turn it on again the amp dont turn on i dont know why
Check the remote lead and see if it is getting power at the amp when it won't come on that way you know if the issue is with the head unit or the amplifier.
Mar 08, 2011 | Jl Audio 500/1 Car Audio Amplifier
Amp sound fuzzy and out of tone.
Well if you want goo dpinch harmonics to squeal you need a decent amount of gain and good pickups. What guitar are you using, some lower model passive pickups have bad frequency response when you try to do pinch harmonics. If you have decent pickups I would say get a higher gain preamp and just run the amp on the clean channel. There a re tube preamp pedals out there that have masaive amounts of gain and they are reasonably priced. There are also so good amps out there for a decent price like the 6550 from peavey. I have a 5150 block letter and that thing can produce good pinch harmonics along with my EMGs. Good luck man, oh and there is nothing wrong with your amp, it is just time to move on. There is only so much you can do with solid state amplifiers in my opinion.
Jan 13, 2010 | Music
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
Kenwood KAC 7502 Amp trouble
Exchange the amp it is going into Protect. But your sub may be causing this problem if it is shorted. Make sure your subs are wired to at least a 4 ohms. Only a shop can tell you for certain if your sub is shorted or not. But if you are smelling smoke then that amp is already toast.
Jun 26, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Bazooka EL1500 Car Audio Amplifier Logo
212 people viewed this question
Top Bazooka Car Audio & Video Experts
Radames Pagan
Radames Pagan
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
